Originally Posted by dave pawlowski
(Post 1568711680)
The OP showed about 3 db reduction after the dynamat installation. Trouble is, 3db, while noticeable, is not extremely dramatic. You need 10db to be half as loud. I don't think that is practical with add-on dampeners.
Here is a reference is case you want to look at it.... http://www.testeq.com/charts/decibels.lasso The problem is we also hear sound is a log scale (dB). So although 3dB is a significant power reduction it doesn't sound dramatic to our ears. :bigears |
At this point, it's cheaper and easier just to dump the BB fusions and get yourself a quieter exhaust. I think what you found is that only serious mass loading, lead septums, etc is going to make a dent and you probably aren't interested in the cost and weight.
Originally Posted by TLK
(Post 1568716111)
Originally Posted by cmonkey713
(Post 1568687704)
The rear tire noise is the main reason to sound deaden. If you are still running the Goodyear runcraps the tire noise is terrible. I have Borlas, longtubes and cats, the drone is very noticeable but the noise from the rear tires is much more annoying. If you have a bone stock C-6 coupe the tire noise is very annoying at speeds above 60 MPH.Forget about the exhaust it's the tires that drive me crazy. :thumbs:
Originally Posted by 95blklsc
(Post 1568713319)
You are wrong. 3dB is half power.....
I have NP with exhaust noice or drone.My C5 is livable around town under 45 MPH.The problem I want to clear up is road noice on the highway at 60 & 70 MPH.I have Fauken tires and it's bad enough to affect the radio no matter how loud you have it.Any suggestions.Is the stuff from Home Depot or lowes a waste of time?I just did the inside of my drivers door.I taped it in place.Does glueing it make a difference?
Thanks. |
Originally Posted by gota07
(Post 1568696801)
I'm going to make a guess that NVH stands for noise/vibration harmonics.
Coming from someone with permanent hearing damage you should get rid of that loud exhaust, its not worth it..
Originally Posted by Silver99v6
(Post 1568723799)
:iagree: After sound deadening mine, I can't hear a semi truck next to me, but I can hear the freakin' tires! It's so annoying. :crazy:
Thanks. |
Very informative now what is the best material to use?
im supprized you saw that much different with only 12 sqft in an 80 sqft cabin
I've done several vehicles I owned (Dynamat Xtreme) I did my C6 street car from the rear hatch seal all the way to the dash and everything in between including the doors. Probably added 50 lbs of the stuff. It will not get rid of drone, at least not enough to justify the $$ and effort IMO if eliminating drone is the goal. Only changing the Borla to a Corsa got rid of it on mine. As far as the tire noise, it is quieter than before, and doesn't sound that loud at all to me. It has the Z tires and suspension on it.
If you only do a section of the car it has been my experience that the noise will shift to the areas that have not been done where it can still resonate. |
