https://cimg5.ibsrv.net/gimg/www.cor...f962f2767d.jpg
I have placed the spring connector on there as firm as possible without forcing it and this is what I have. From those of you using the same set up, how does this compare and any reasons for concern about quality of connection? Obviously not mounted on battery. |
If you can't scootch that connector side-to-side with a couple of fingers then I'd quit worrying about it...
Originally Posted by Panama 58
(Post 1599220215)
Originally Posted by Chuck Gongloff
(Post 1599220264)
"Unspring" the battery cable a scooch.. and push it down a bit.. No worries.
Originally Posted by Frankie the Fink
(Post 1599220270)
Congrats on being a 20 year member Chuck!
I don't have 20 years of experience. I have ONE year of experience..... repeated 20 times. :D Here I am today, with my buddy John, at a car show close to home. https://scontent.ftpa1-2.fna.fbcdn.n...8e&oe=5D2F3C8C |
I know many favor the blade switch, but I can't see putting something reminiscent of a 1920s railroad signal tower in a relatively modern automobile like a Corvette. Save the blades for the pre-war cars and use a Hella or Cole Hersee in the Corvette.
Originally Posted by ejboyd5
(Post 1599220700)
unlike the green knob the blade switch can’t fail. |
The knife switch is simple, nearly foolproof and on my 63 its tucked up under the fender so far its not very visible at all...
I have no problem with it whatsoever.. |
Here's a picture of a Hella switch installed in he passenger's side footwell of a 19
https://cimg5.ibsrv.net/gimg/www.cor...b44292c1b7.jpg 61. |
(Post 1599220909)
(Post 1599221719)
It does come from Hella's marine line. Easy to reach from the driver's seat and handle is removable for some small degree of added security.
Here is the deal with the "knife vs knob" story IMO....
The knife switch has a constant pressure to make the connection provided by the spring-style clip that the blade drops into...never changes and is constant. My experience with the green knob devices is that the pressure to make the connection varies, I tend to crank down on the knob pretty hard to make sure starter current can flow through it. Eventually, this requires more and more effort and, between corrosion and the distortion of the constantly, increasing tightening force - the switch fails... Its that simple to me... Besides - throwing the knife switch is just plain cool: https://cimg9.ibsrv.net/gimg/www.cor...de0ad112e8.gif |
(Post 1599219396)
You've been lucky - I've been through about three of them (not the cheap ones) and each one eventually resulted in a non-start condition..
What is your primary purpose to have this installed??? Battery Drain???
The REAL Professionals love the silent cars without LOUD theft sirens/horns. They own Tow Trucks and (enclosed) Tow Truck Trailers for a fast get away. Only the amateurs might get fooled....only for a while. |
For me not theft or battery drain so much as fire 🔥 when not around burning the car and/or house to the ground if I’m not there. Not an uncommon occurrence with these cars:eek:
If you have a mechanical dash clock, disconnecting the battery when the car will sit idle for a while extends the life dramatically...
If you have a clock refurbished by Clock Works they include a tag stating that in their maintenance instructions... If your car is anywhere close to decently maintained, fire should not be a major concern... Some forget people actually drove and PARKED these cars for days at a time in their garages 60 years ago... I can't remember ever seeing a battery disconnect on them back in my used car dealer days... |
Originally Posted by Vette5311
(Post 1599224991)
(Post 1599219396)
(Post 1599224991)
(Post 1599225026)
If you have a clock refurbished by Clock Works they include a tag stating that in their maintenance instructions... If your car is anywhere close to decently maintained, fire should not be a major concern... Some forget people actually drove and PARKED these cars for days at a time in their garages 60 years ago... I can't remember ever seeing a battery disconnect on them back in my used car dealer days... I've mentioned it before, a buddy who is a retired fireman said they'd get called out about once a week for an electrical fire involving a car. Because of that, he faithfully disconnects the batteries on all his older cars when he isn't around. I understand your point on a "decently maintained car" but, well.... s**t still happens and it's so easy to prevent it that I just disconnect. You spends your money and takes your chances. Completely agree that making your clock last longer is a happy bonus. Cheers. :thumbs: Respectfully, Thomas |
