Originally Posted by CMYC4GO
Unbelievable... :skep: :leaving:
Originally Posted by bigcityvette
do you have the egr hole under the plenum lid sealed with the superram? if not you car will run and idle bad.
Originally Posted by hippy
Why don't you just drill some small holes in the T/B blades? Maybe your IAC just needs to be reset AGAIN? Maybe your TPS voltage needs to be raised above 1v. at idle?
P.S. Kid, you didn't solve sht, you just masked your problem. |
Set the TPS to .54
Originally Posted by USAsOnlyWay
Ok, its late and I haven't read over all the thread.
But here is something to try. If Bill is on to something. It may be that you are sucking in gas into your intake and causing your problems. Try this. 1)Unplug the vacuum hose you have and note how the car idles. (Obviously you have done this, and it appears to idle just fine) 2)Take the now "vacuum leak" you created and plug that port on the tb. Not with the original vacuum line. But just with a plug. My thinking is this, with this port plugged. The charcoal canister system is completely cut off from the system. Also you are no longer relying on an un-metered air supply to keep the motor running. Unforunately I am without my manuals so I am unsure on how the charcoal canister system works. But I will assume my logic is mostly correct here. Now, if it still idles like crap. I would put the charcoal canister test on hold and dismantle your TB. (Actually it would be better if you could use a code reader to see what the IAC is doing(or even working), but barring that....) Pull it apart and remove the IAC valve (Carefully) clean the entire thing out until it is clean. My thinking is, HYPOTHETICALLY saying that you have a working IAC valve. (Which may not be the case) You may have it so gunked up in side the TB that the IAC valve is not able to meter the correct amount of air in to allow the engine to idle. Then reset the TPS/IAC valve using the proper procedure explained in the Tech Tips. I urge you to do this. And do it right! If the motor did idle fine. Then continue on testing Bill's hypothesis and see if it is indeed drawing fumes into your plenum. Let us know how this goes and we can try to move forward on this problem. On other thing. Don't go drilling or anything like that. You don't need that. The system should run fine without it. Hell you are on a stock cam aren't you. Just don't do anything permanant till you knocked out the easy stuff. Also a few other questions: 1) Did it have this problem pre-SR install? 2) Did it have this problem immediatly after SR install? 3) What parts were reused on SR install? (TB/IAC valve???) Did ALL of that. I have always had this idle problem even with my stock intake + a hard start. Back then, my injectors were leaking which in turn caused the hard start. Took off my IAC. It looks like it is in perfect condition. In fact, I bought an IAC and put it in place of the one I have right now on my car. Still, it did the exact same wandering idle. Apparently it wasn't the IAC valve even if I tried the new one. I returned it and got my money back. A fellow CF member told me that my whole tune is still very rich, especially at open loop mode. That would also explain lack of power and my 9 second passes in the 1/8 mile strip EVEN if I had on the SRI and tuning. |
Set the TPS to .54
ps: Yes, my IAC and the TPS have been reset for the 253894572nd time as well. :willy: |
Originally Posted by kopbet89c4
So far, this is my "controlled vacuum leak" much of like what my IAC is supposed to do but has never controlled the idle as well as this "vacuum leak" mod.
Since the IAC hasn't worked properly, as evidenced by, "my IAC is supposed to do but has never controlled the idle"", Why don't you spend your time [B]FIXING]/B] the IAC system, rather than searching for a way around it?
This is much like the "drilling holes in the TB plates" mod that many other CF member have once asked about.
Maybe my pcmforless.com tune isn't as perfect as I have once perceived it to be. Sorry Alvin, but I might have to send back the piggyback chip to make sure you did everything right in order to use the EVAP canister like the General wanted originally. Or is it perhaps using 22# factoy flow injectors from Bosch? TIA :cheers:
Are you really this stupid? Or just this stubborn? :smash: RACE ON!!! |
Since the IAC hasn't worked properly, as evidenced by, "my IAC is supposed to do but has never controlled the idle"", Why don't you spend your time FIXING the IAC system, rather than searching for a way around it?
here we go again
Looks like my old buddy "Richard Cranium" is at it again!
When somebody has such an aggravating problem, the last thing they need while being frustrated is to be insulted, or talked down to. I thought the whole idea of this forum was to help each other through the problems we encounter and share our experiences. I dont care how much knowledge some of you have, being an a-hole is still being an a-hole. Cut the guy some slack and try to help him, and maybe be a little understanding! :toetap: |
You obviously haven't read the original posters previous posts and the advice he was given. Talk about advice falling on deaf ears. |
i understand
I provide tech support all day for heating and a/c contractors, and from what I see sometimes you get so frustrated trying to fix something that you just dont get it, even when good advice is given. And when you add in the fact that its your personal vette, that doesnt help either. Just wanted to voice my opinion on certain posters attitudes. At one time or another we have all been there!
RACE ON!!! |
my opinion
My opinion is this, he has already frustrated himself to the point he's not thinking rational, If I knew the answer I would try and help him, what ever it took. I think he should bite the bullet and take it to somebody who knows and just get it repaired. As far as my opinion being kept to myself, every time I see you insulting somebody from now on you can bet I will put in my two cents! If you have the knowledge your supposed to, why dont you explain away. Otherwise try and be a little compassionate to people.
p.s. have a nice day! |
RACE ON!!! |
In fact, I still have all the EGR stuff on my car but the EGR tube itself is blocked off with a plate. I always thought you don't use EGR on start up, idle and WOT?!?! Isn't EGR only used during light throttle and cruising?
to the original poster, i'm re-posting this advice, its your best bet:
Get that car in the hands of someone qualified befor you hurt that motor....Did you get the correct MAF yet?
and don't you dare even insinuate that pcmforless has anything to do with your current problems. i too, hope that alvin reads this thread. he would crap his pants. Are you trying to tell us Alvin has a fecal incontinence problem? I don't think he'll appreciate that. J/K Alvin. :lol: |
:lol: well alvin might develop one, if he hears what this kid is doing to screw up his tune!
