Originally Posted by ddawson
(Post 1592820257)
So when two parts come together like the rear section do they over lap or butt up to each other? Looking great so far.
I will see if I can get some pictures of it. Good question, thank you. David Howard AllC34Me |
Dave looking great. what size tires do you have on it.
Originally Posted by FINWOLF
(Post 1592820706)
David |
Looks great!
Originally Posted by AllC34Me
(Post 1592820735)
Mickey Thompson 295/50-R15 front and rear.
David I hope you didn't take my "budget" remark wrong, I mean that it appeared to me you desired wrap over paint meaning you saw pros to it, Can it go over primer? How long will it last? Many thanks! |
can they match the paint that is on the car .I want to wrap the new front and rear rubber bumpers.
(Post 1592821788)
How about rim dimensions?
I hope you didn't take my "budget" remark wrong, I mean that it appeared to me you desired wrap over paint meaning you saw pros to it, Can it go over primer? How long will it last? Many thanks! My understanding is you cannot put it over primer, it needs something to adhere to and primer does not have the proper surface tension. Depending upon thickness and use you can get 5-10 years life out of the wrap. There are various types of vinyl that can be used for the wrap. The real strength to a wrap is over new paint as a protective coating. I should have considered something like this on top of my new paint job on Sparty. All but eliminates stone chips. Hope that helps. David |
Helps and hurts,
I love your rims and finally know I will be happy with the 295 50's all around and it will work and fit...win I will be in primer, mike and tommy damaged way too much of my car for it not to be primed so I guess a wrap isn't gonna happen for me:( |
Could easily shoot some cheap paint over the primer and then have it wrapped bats?
Originally Posted by terry82
(Post 1592821813)
I'm going to be updating my information on the car build which is located here:
https://www.corvetteforum.com/forums...as-sought.html If you have any further questions I will check here for them and help as I can. Thanks for the discussion folks, good stuff. David Howard AllC34Me |
4 Attachment(s)
(Post 1592819613)
<---SNIP---> Logos have been selected and will include Sunoco Racing Fuels, GM Performance Parts, Detroit Vintage Wheels, Holley EFI, Mickey Thompson Tires, Hooker Headers, and Summit Racing. I will also have the Seven Wraps Logo on the car. Others? <---SNIP--->
(Post 1592821788)
<---SNIP--->
Can it go over primer? How long will it last? <---SNIP---> Actually, I would call Geek Wraps in Ft. Lauderdale and ask. AFAIK, you can apply vinyl wrap on a lot of surfaces, but for a car, I am sure you want it to be as flawless as possible. I read in one of the vinyl wrap forums a while back, someone recommending spray bombing the primer with clear, in order to provide better adhesion. Not sure if this is correct and again, a vinyl wrap pro can most likely answer that question. Here's a video (only the first couple of minutes show a C3, of all things) of a car being wrapped. It's truly fascinating to see how they can literally sculpt the vinyl so it conforms to complex surfaces. As far as life/durability, I think both 3M and Avery have 5-year warranties, but that may be for printed vinyl, so that's something else to ask Geek Wraps. Or they can give you contact info for an installer near you. (954) 783-3117. |
Originally Posted by CFLVette
(Post 1592829528)
Hey Bats, you may want to check with someone who specializes in car wraps. Sign shops have different standards.
Actually, I would call Geek Wraps in Ft. Lauderdale and ask. AFAIK, you can apply vinyl wrap on a lot of surfaces, but for a car, I am sure you want it to be as flawless as possible. I read in one of the vinyl wrap forums a while back, someone recommending spray bombing the primer with clear, in order to provide better adhesion. Not sure if this is correct and again, a vinyl wrap pro can most likely answer that question. Here's a video (only the first couple of minutes show a C3, of all things) of a car being wrapped. It's truly fascinating to see how they can literally sculpt the vinyl so it conforms to complex surfaces. As far as life/durability, I think both 3M and Avery have 5-year warranties, but that may be for printed vinyl, so that's something else to ask Geek Wraps. Or they can give you contact info for an installer near you. (954) 783-3117. https://youtu.be/Uv8Xpr-8Qt0?t=30s |
(Post 1592829528)
Actually, I would call Geek Wraps in Ft. Lauderdale and ask. AFAIK, you can apply vinyl wrap on a lot of surfaces, but for a car, I am sure you want it to be as flawless as possible. I read in one of the vinyl wrap forums a while back, someone recommending spray bombing the primer with clear, in order to provide better adhesion. Not sure if this is correct and again, a vinyl wrap pro can most likely answer that question. Here's a video (only the first couple of minutes show a C3, of all things) of a car being wrapped. It's truly fascinating to see how they can literally sculpt the vinyl so it conforms to complex surfaces. As far as life/durability, I think both 3M and Avery have 5-year warranties, but that may be for printed vinyl, so that's something else to ask Geek Wraps. Or they can give you contact info for an installer near you. (954) 783-3117. Thanks it is an option I have to look into more, there are some stunning results |
(Post 1592828933)
Corvette Forum?!?! :yesnod:
This all is a bit deer in headlights for my brain right now, ac34me's car is so darn stunning, his build is very much what I am going for except his is pristine I want mine to have a patina look like the hot rod guys who air brush or wrap pseudo rust on their fenders,
As far as sponsor labels for me goes, I have hit companies many times and they will normally jump right on it and send you free decals it is after all free advertising for them, coker tires used to send you a cool tire key chain just for asking. And I had a few ask if I would have interest in an advertising wrap, I was way too far from a running car to consider it, and I would have to at the very least use or support a product that's plastered on my car but when I am closer I will see who has interest, it's surprising what they will just give you when you ask the right person....:thumbs: |
(Post 1592819222)
They want 10,000 bucks to paint my car ,a wrap is starting to look good.
(Post 1592829840)
Seven Wraps is a specialty wrap company only, they are not a sign shop. If you want to check with Brian at Seven Wraps he can answer any questions you would have on warranties, etc. He can be reached at Brian@SevenWraps.com and he is the partner/owner.
As I mentioned in a previous post...
(Post 1592819468)
<---SNIP--->P.S. AllC34Me, your car is looking great. Those guys know how to properly wrap cars for sure!
