Originally Posted by aklim
(Post 1596076050)
I think your bigger concern should be to find a gas station that has fresh gas. IOW, avoid the Mom & Pop stores. Get something with heavy traffic instead of a car every 2 hours. Ethanol has been talked like it is asking someone to take a dump in your tank. If you were having your boat sit at the marina in the water all day long, it might be an issue. Otherwise, IMO, just get fresh gas and forget it. I used to live where they had no ethanol in 93 octane. Didn't seem to help mileage much, if any at all.
As to plugs, get whatever NGK recommends. Install them. Run the car and night and spray a fine mist of water around the wires to see if they are leaking. For the plugs why is everyone stuck on NGK??? Just curious... Why not use the AC Delco R43TS ??? My wires are brand new Taylors |
Originally Posted by 81c3
(Post 1596076159)
Yes, I know about not using Mom & Pops.... I use either Conoco or Shell. Our choices are 85,87 or 91 octane. Traffic is very heavy at both stations... Im 11 miles from the Royal Gorge Bridge... We have a ton of tourism pretty much year round.
For the plugs why is everyone stuck on NGK??? Just curious... Why not use the AC Delco R43TS ??? My wires are brand new Taylors You could. Just happens to be what is common. OK. As long as they are not leaking. |
(Post 1596076185)
Then you should be fine as long as the ECM doesn't pick up pinging to use whatever you want.
You could. Just happens to be what is common. OK. As long as they are not leaking. My knock sensor was also replaced when I did the coolant flush and torqued to 14lb/ft so I believe thats ok... Just seems strange that it didnt do it at all last night... I deliberately tried to load the engine even on the same stretch of road!!! :smash: |
(Post 1596076221)
I assembled the boots to the plugs with dielectric grease as well at the cap towers.
(Post 1596075574)
Sorry, Im not as smart as you I suppose.:hide:
(Post 1596076159)
For the plugs why is everyone stuck on NGK??? Just curious... Why not use the AC Delco R43TS ??? My wires are brand new Taylors People buy NGK because they are a premium plug that just seem to work in any application. AC R43TS is cheap junk made out of the Autolite factory in China. They are not what they were 20 years on back. |
Originally Posted by Cjunkie
(Post 1596076862)
if you cant get pure gas Shell 91 in your area is the best you can buy.
(Post 1596078358)
So I saw a few guys saying that a lower octane fuel is more volatile and I should use that instead of the 91.... I always thought the 91 was the most ping resistant... then some say I wont need it with a low compression L98.... I have iron heads, not aluminum... maybe thats why? Sometimes shit get confusing...
(Post 1596063688)
Same ones in my car kael
I noticed the EV1s had rubber boots on the end, mine don't, they are metal with a inverted conical end. |
(Post 1596078358)
91 will be the most ping resistant. As for reg fuel out of pumps Shell V-Power will be the best you can get. |
Originally Posted by kael
(Post 1596079159)
You mean Lucas? Or EV1?
(Post 1596080408)
The plugs i suggested are for iron heads.
FIC = Fuel Injector Connection, correct? Is this currently the best place to get a set of 30lb? If I'm way over budget already can I go with the rebuilt red ones for $200?
I'm going thru Minneapolis this week, could pick up a set at TPIS listed for $425. They look different from the FIC ones. I'm using a Miniram. https://cimg5.ibsrv.net/gimg/www.cor...f0b20a8e1f.jpg https://cimg6.ibsrv.net/gimg/www.cor...5508579594.jpg |
Originally Posted by ryank9398
(Post 1596112601)
I'm going thru Minneapolis this week, could pick up a set at TPIS listed for $425. They look different from the FIC ones. I'm using a Miniram. https://cimg5.ibsrv.net/gimg/www.cor...f0b20a8e1f.jpg https://cimg6.ibsrv.net/gimg/www.cor...5508579594.jpg They should. The FIC red ones are the later design compared to the TPIS reddish-brown ones. Miniram won't know the difference. |
Identical prob here. There is another thread I started.
Still have not pulled the plenum to do the injectors to see if that's it. |
