What's the trick?
I have a 96 CE, and i am trying to get the inner drivers side door panel off but i am having difficutly getting the door latch and lock slide trim out. It seems like somethings holding the lock slide plastic piece in place. HELP!!!!!
If you pull the slide lock plastic off you will find a screw. You have to pull the slide away from the door towards you. You will also find another screw behind the light ablove the door handle. Use something slim to pry the light out from the top. I use a small putty knife. Hope that helps.
Did this help?
