best tires for the money????
anybody have a good answer on the best tires for a c5 .best bang for the buck thanks.
If you are not looking for run flats. I had good luck with the Nitto 555
Form Discount Tire $106 fr $193 rear http://www.discounttiredirect.com/di...999&vid=004486 |
only problem with 555s it has a w speed rating not a y rating
Speed rating ZR
http://www.discounttiredirect.com/di...d=004486&ar=45 |
tire 245-45zr-17 89w the w is the speed rating w-168mph y-186mph fyi the 89 is the tire load rating .thanks david
Ive been researching the same thing. Been reading all the tests,surveys, comparisons, etc. on the tirerack site. after reading everything i could find I am going to go with the Kumho Ecsta MX in a non run flat. 50-150 cheaper per tire than the big names but right there with the F1 supercar tires for dry grip , much better in the wet, quiter, and longer lasting tread life. go to the tirerack site and compare the max performance tires. You will get pretty much all the info you need to try and pick what is best for the kind of driving you do. There are about 50 corvette owner surveys on these tires plus all the specs and tests from the tirerack. There are better tires for track only, or wet handling, price only, but for all around do it all ( track, street, wet, dry, & price) the Kumhos look hard to beat.
They compare very well to my last 2 sets which were Firestones and Goodyears. I got about 40,000 miles on Firestones. |
I have the Kumho ECSTA MX tires and love em. :thumbs:
KUMHOs or NITTOs are gonna be your best bet IMO
--Marc |
Toyo T1-S :thumbs:
awesome tire dry and wet. ~$800 for a set. |
thanks for all the imput. david
Kuhmo's MX!
Discount Tire Direct has awesome deal on Pilot Sport 2. I would get those if it was me.
Dunlop 9000s are pretty good tires for the money. The last time I priced them it was 650 for all four shipped. Sizes are slightly different I believe, I think you have to go with a 285 255
Kumho MX with all the little partridges...
another vote for the Kumho Ecsta MX
