Front ride height - finally at 27.25" --- new photos
Just installed my new 550lbs coil springs today - ride height is at 27.25" (floor to fender lip @ center of wheel) with 255-60-15 tires.
:party: I hope the springs don't settle too much, haven't driven the car yet.... :) |
worthless
without PICS :D |
Congrats on an acceptable ride height, you are a rare breed. Are those VPB or others ? I hope they are because that is what I installed on my '80. It will be another 1 to 2 months before my car touches the ground for the big test. Brent
Originally Posted by Redshark6974
worthless
without PICS :D I knew it........ :D Here's a photo of the car with the 460lbs springs and 1/2 coil cut off - ride height was at 27.75" .... I'll post a photo with the new springs installed tomorrow - once they are "approved" http://forums.corvetteforum.com/phot...009904-med.JPG |
Yes VBP - I ordered on Monday and received the springs today.... great service, fast shipping :thumbs: Just like they told me on the phone : 27.25" without cutting anything off the spring |
I like my cars a bit lower, call me crazy yours looks awesome and it should handle amazingly, but Im more of the 25.5-26" sorta crowd
Isn't it great when a plan works out?
awesome dude. What do you use for the rear leaf spring? I am thinking about replacing mine to a 460# front. I am till deciding and researching on the rear leaf springs. awesome
WOW!! Nice ride. Get a red one next time!
Pardon my ignorance, but can someone explain how an installed spring with a higher spring rate causes a car to ride lower? I would figure the opposite to be true.
Thanks, D. Ocean Miami, FLA |
The higher spring rate springs are shorter with less coils than a stock spring. :) Boing
I do wonder what the height will be with a Big Block in there hmmmm. Any thoughts on that one? |
When you do finally drive it, tell us if you notice any difference in the ride.
Here is a picture of 460s (left) and 550s (right). You can see the difference in height.
http://img.villagephotos.com/p/2004-...ng6(Small).JPG |
same number of coils tho...
Yea, I'm courious about the changes in the ride also....
Here are two photos showing the ride height after installing the 550lbs springs.
http://forums.corvetteforum.com/phot...00811small.JPG http://forums.corvetteforum.com/phot...00817small.JPG |
And they don't rub lock to lock?
of course they do - that's one reason why I don't drive the car :willy: They hit the front of the fender when turning, I guess I have to remove the 1" spacer or install 245-60 tires instead.... I really don't want to cut fiberglass to make it fit... |
