92’ LT1 injector resistance??
It may not be a problem, but I just checked all my injectors,
1=12.0 3=12.1 5=12.0 7=12.3 2=12.4 4=12.3 6=12.3 8=12.2 I read somewhere that the injector resistance should be between 16 and 17 ohm’s. Could someone with a 92’ and stock injectors please test their injector’s resistance and let me know what you get. Thanks Denver. |
The Helms manual for my '91 says that all injectors should be within 1.0 ohm of each other and should not be less than 10 ohms at 70F. :cheers:
'92 injectors are supposed to be 12 ohms.
Tom Piper |
I'd say you are fine... the chance of all injectors is quite uncommon. if you have a significant variance I would then worry...
Mo |
The last time I measured my injectors on my 96, they were:
1-3-5-7 (12.1, 12.0, 12.1, 12.1); 2-4-6-8 (12.1, 11.9, 11.9, 12.1) They were measured cold. Hot, they'd be a tad higher. When I measured those on my 88 several years ago, they were: 1-15.9; 3=15.8; 5=15.9; 7=16.0; 2=16.0; 4=15.9; 6=15.8; 8=15.7 |
How do you check them?
