Fuel guage
I am having inconsistent readings from my fuel gauge. It started a few months ago and it almost left me stranded on the highway. Anybody else having this problem? I drive mine everyday so it is not sitting or anything like that, I try and keep it topped off but on long trips it is a concern. I know some people are having problems with the DIC part that deals with fuel, but have not seen anyone mentioning my problem.
Why is it a concern, just determine on average how miles you get to a tank full and set the trip odometer each time you fill up. I rarely look at the gas gauge and go by miles driven.
BTW the dealer can fix the faulty gauge. Also your DIC will tell you when your fuel is down to reserve level, so I don not understand how you could run out of gas. |
The problem is that DIC goes from nothing to Low Fuel and Check Guages instantly without the Reserve Fuel ever coming on. The other reason why it is hard to estimate is my extereme driving style. I either drive in the city for many tanks at a time managing 12-15 miles per gallon or drive on the Florida Turnpike averaging 26-29 miles per gallon for many tanks, so I have no middle ground to go by.
Originally Posted by barondw
Why is it a concern, just determine on average how miles you get to a tank full and set the trip odometer each time you fill up. I rarely look at the gas gauge and go by miles driven..
It's a computer problem. I have had this happen as well. I beleive there is a bulletin on this issue. Take it to your dealer, you prom needs to be re-flashed. Count your miles.... :lol: |
I am also having a problem which started at about 29,000 miles. The gauge is OK until half tank, and then it goes to zero. The problem is eratic, but happening more often. Someone recommended a solution but I didn't bother since I had to put it up for the winter.
Take it in to the dealer. It is a known problem and they replace the Fuel tank sending unit. I had mine done a couple of months ago. Same symptoms as yours. Good luck until you get it fixed.
just curious, how is GM keeping customers when issues like this and the leaking rear end come up with so many owners yet they charge us to fix it??? It seems to me as few of these cars as they sold they should consider all these issues a design flaw or at the lease a planning flaw and fix it regardless of mileage or time. I understand that some guys are beating the hell of these cars but the naging electronic, sending unit, etc. is not part of hard use problems. :sadangel:
I had the fuel gauge issue but cured it by using Chevron TECHRON Concentrate Fuel System Cleaner (about $5; widely available). One bottle added to a neary empty tank immediately before filling up.
Used the TECHRON twice and the issue has not recurred in the past six months. Might want to give this approach a try before making a trip to the dealer. Ranger |
Thanks Ranger, I already started doing just what you suggest with the last tank of gas. Will report how it is going. What is so funny is I use only Chevron premi unleaded with Techron in the thing and itr still happened. :iagree:
The fuel guages have been known to register 1/4 full when they are in fact nearly empty. Thus, the "reserve" light never comes on. Other times, the gas guage will go from 1/2 full straight to empty and the "check guages" light will be glaring at you even if you have plenty of fuel. :crazy: Only GM could screw up something as simple as a fuel guage. Anyway, as long as I'm using Chevron gas, it doesn't seem to have a problem. |
I just looked at MSN autos and they say GM is going to want $370.00 plus 2 hours of labor to fix it. Boy am I glad I bought an extended warranty.
The other thing that I have heard is that some fuel mixtures are to blame, something about sulpher or ???? that Gm changed the sending unit in 02' and then changed again in 04' and only 02-03 are experiencing this problem. Every one says that it starts at 25k plus and that it gets worse as time goes on. I'm up to 29k, and mine would return to normal if I put a couple of gallons in at first. Now it has to be filled and even then is slow to respond. But it doesn't happen on every tank of gas. I use Techron, and not just the fuel injector cleaner with it, but the full blown Techron. I was using Sunoco, but have had it happen with just about every brand of gas but BP/Amoco, which I for some reason don't want to use. (probably one of those things that my father told me 25 yrs ago about one of them?????). Oh well another .02 in the pot. |
I had the same erratic fuel guage problem on my 02. Had long friendly discussion with mechanic at dealer after they fixed it under warranty. I'm also retired employee of major oil company. Problem is not fuel related, but apparantly the car has two sides to the gas tank with two sending units. One goes bad and screws up the readings to the fuel guage. It is usually intermitent... some times you fuel up and guage will read 3/4, other times the guage will drop 1/4 to 1/2 in just a few minutes.Seems to be a known defect with the vehicle and you could probably make a strong case for warranty repair even if you are out of time or miles. Good luck.
...I know some people are having problems with the DIC part that deals with fuel, but have not seen anyone mentioning my problem.
You can try the warranty fix, or some Techron. |
Other times, the gas guage will go from 1/2 full straight to empty and the "check guages" light will be glaring at you even if you have plenty of fuel. :crazy: Only GM could screw up something as simple as a fuel guage. Anyway, as long as I'm using Chevron gas, it doesn't seem to have a problem. You guys might want to check the C5 Tech and General from time to time... The large number of non Z06 C5s are going to show common problems quickly. You can purchase Techron from most auto supply stores ($10), this seems to be doing the trick with 2 usages... If you don't want to try the Techron, a dealership will be happy to replace sensors for about $350. Good Luck As you can see by my Avatar I am a regular C5 :lol: http://img.villagephotos.com/p/2005-...ostTechron.JPG |
