81 running on c 6yl?
Hi, Im new to the forum, and to the vette world. I hope someone can help with my first problem.
The car was running fine, pulled into the garage one nite, the next evening, got in to take it for a ride and it sounds like its running on 6 cyl. Starts and idles fine, but no acceleration. very little backfire, very rich exhaust smell. New plugs, cap, rotor etc. Im not sure what to look for as it was running fine. Next time it was started, it acted this way. Any ideas what to check would be appreciated. Ron |
Ignition module failure--or you changed the firing order--or a plug wire got too close to your exhaust manifold.
In addition to the above, if your computer system is still intact and functional, the above could be a symptom of any number of things from a failed thermostat to a faulty sensor.
thanks |
The computer may have taken a bump on you and may be in "limp home" mode. Carburetor may have swallowed some garbage. Float stuck open.
BigBlockk Later..... |
I unhooked the battery and hooked it back up and all is fine.....
this is happing all the time now, I dont know the sensors locations and the manuals and the zone isnt any help.. tersian, your email isnt up to date...email me please... rtdmonst1@hotmail.com...
