will 3rd gen camaro rims fit?
On an early C4? I wan't a spare set of tires to abuse and can get a camaro set cheap.
Yes Camaro wheels will fit. I use the chrome wheels off of a 98 Camaro fitted with drag radials for racing on my 89 vette. The fit no problem.
John |
if you still own an '85 like your profile says, yes they will fit.
They don't look funny because they sit too far in or too far out?
they are the same offset so it should be the same. i have a 96 so i couldn't tell you how they look.
I thought 93 and up was 4th Gen?
If they are before 93 they will probably fit, but stick out pretty far. You'd be looking mad pimp yo! :D |
From the AFS site
THESE WHEELS ARE CUSTOM MADE FOR THE 1984-1987 CORVETTE! 17x9.5" (+38mm, 6.7" backspace) front 17x11" (+36.5mm, 7.397" backspace) rear. They are a direct bolt-on and no spacers or adapters are needed. They also fit on the 1993-2003 Trans Am, or Firebird! Please note, this is not the correct offset for the Camaro. |
I ran the DR from my '86 IROC on the '88 Vette for a few passes and, yes, they did stick out a little.
found a nice set of wheels 16 x 8 like zr1 rims would they fit r 1985 corvette
Love, Hugs and Kisses Rachel |
The third gen rims will not fit or not well. They have a different offset from 4th gen rims which do work.
