oil drain plug size
What size socket/wrench do you use for drain plug?
5/8ths I believe.
I just did mine last weekend..... 9/16
I use a 14mm socket for my drain plug which fits good and tight.
oil drain plug size
Hi
I use a 9/16 & a big drip pan. Tomcat 74 :flag: |
9/16 six point here but 14mm and 9/16 are really close in size.
14mm is the correct size. Depending on amount of abuse your fit may vary.
I believe Jerry's has new drain plugs and the correct washer so you don't have to over tighten. Remember, you are going into aluminum!! |
Originally Posted by fxkenny
(Post 1599139930)
I believe Jerry's has new drain plugs and the correct washer so you don't have to over tighten. Remember, you are going into aluminum!! A 9/16 is .5625 and if the oil drain plug has seen a little abuse the larger 9/16 will work a bit better. If the oil drain plug is tight, the 14 mm will give a better grip. I always coat the washer both sides and the threads of the oil drain plug with a bit of Permatex which helps secure the plug with a little less torque as fxkenny suggests to not overtighten :thumbs: You are going into aluminum but...….the aluminum oil pan has a steel Helicoil insert for the Oil Drain Plug. |
zf s6 -40 transs.
drain plug 1994 corvette 6 speed manual . drain and fill plugs. m24x1.5. 17mm.
