chassis lube points
Does any one have a lube chart showing where the chassis is supposed to be greased? Or is it any on a C5?
Thanks |
None on OEM car ... only if you have put on aftermarket suspension parts with grease zerks
Pretty easy, eh? |
Well thanks Guys. Just wanted to be sure. I'm from the old school where you had to grease them about ever 1000 miles or so or the wheels would fall off.
Originally Posted by Subdriver
Their not cheap either, about $400 a wheel. :eek:
Wheel bearings on the car are sealed units that will last the life of the car for most guys. However, if you track your car regularly, they develop play and will likely need to be periodically replaced. I change out my wheel bearings, which come as a composite unit complete with the ABS sensor, about annually. Their not cheap either, about $400 a wheel. :eek:
Originally Posted by Ttop34
Are you buying them from GM? Why not use the ones from Autozone? Those come with a warranty so if they go out, just take them back and get replacements!
