-   C4 General Discussion (https://www.corvetteforum.com/forums/c4-general-discussion-34/)
-   -   What is the recommended tire pressure (https://www.corvetteforum.com/forums/c4-general-discussion/127605-what-is-the-recommended-tire-pressure.html)
MagRed_04 08-04-2001 04:44 PM
What is the best tire pressure for Goodyear GSC 275/45/17?
Husker Vette 08-04-2001 05:20 PM
Re: What is the recommended tire pressure (Vette_Crazy)
Most tires have this imprinted on the side wall of the tire........ I would suggest starting there....... :cool:
Ruby_Roadster 08-04-2001 06:51 PM
Running mine @ 34/36psi for the road - @ 40psi for the track
Crushinator 08-04-2001 10:57 PM
Re: What is the recommended tire pressure (Husker Vette)
Uuuh, that's the MAX tire pressure, not the pressure you should run. Look inside the drivers side door. There is a sticker that gives the recommended tire pressures for front and rear. Mine says 32 psi both front and rear for 275's at all 4 corners. My rear are 315's so I have them at 34 psi.
DON M 08-05-2001 08:54 AM
My sticker says 30 psi. I recently went to 315x35x17" w/11" rims on the rear and I don't know what to run. The original owner had 35 psi all around and the tires were evenly worn. What to do?
Corvette Kid 92 08-05-2001 01:06 PM
Re: What is the recommended tire pressure (DON M)
I always put it a little undermax. Don't want those damn things going flat on me :crazy:
billyhay 08-05-2001 03:25 PM
:D
https://www.corvetteforum.net/c4/billyhay/stick.jpg
VET 350 08-05-2001 04:54 PM
I run 35 all the way around :jester
Fang S-289 08-05-2001 05:33 PM
Re: What is the recommended tire pressure (VET 350)
The owner's manual calls for 32 PSI. But I agree with VET 350, 35 PSI does it for me. Handling feels tighter.
scorp508 08-05-2001 06:35 PM
Re: What is the recommended tire pressure (Fang S-289)
I run 33 figuring that they'll heat up to 35 on their own. http://www.corvetteforum.cc/ubb/smile.gif
mackeyred96 08-05-2001 06:55 PM
30/32 psi.
Yello95 08-06-2001 04:51 AM
[QUOTE]What is the best tire pressure for Goodyear GSC 275/45/17? [/QUOT
On the side of my Goodyears, it says Max 35psi...on the door sticker, GM recommends 30psi all the way around and mine runs fine like the GM engineers say to run it...But who knows?...
:smash:
:confused: :rolleyes: :D
CowboyNVette 08-06-2001 07:03 AM
Re: What is the recommended tire pressure (mackeyred96)
30/32 psi.
Ditto :seeya
mshipon 08-06-2001 01:51 PM
I usually run 33 psi all around with stock wheels/tires.
Raysur 08-06-2001 02:44 PM
I use 30psi all around.
rubyred93 08-06-2001 06:35 PM
32 psi here :yesnod:
Paul T 08-06-2001 06:38 PM
35psi is what sticker inside door call for so that's what I run mine at.......
