fuel lines?
I heard someone ask about where the fuel line is on my car and that you can determine a BB from a SB car that way? Which is which?
Fuel lines should basicly be the same for small block & big block. Difference is in the carbs. The Q-Jet has a return fuel line. So you should have two lines on the passanger side frame rail. The feed line and the return line. The Holley did not have a return line so there would only be a feed line on the passanger side.
tom... |
