F41 Suspension Question
I am looking over my 68 L89 that I just bought and was wondering if I have the F41 suspension option. What are the telltale signs? The shocks have been changed unless Monroe shocks are part of the F41 option. I just measured the front sway bar and it is 15/16". The rear leaf spring is 7 leafs. I couldn't find any tags on the front springs. Anyone out there able to interperet this info and what else do I need to look at? Thanks, Mike
Production shocks cary a GM# 3171488 for the front and 3171489 for the rear with date codes that would confirm originality. So...Monroes don't count! From what you list...you've got F41! |
Shocks are F41 only, If only I knew what they would be worth to the NCRS crowd I would not have thrown out my original shocks when I bought mine in 85 :willy: :willy: :willy:
...redvetracr |
This is not my ebay listing, but figured I would post it to help out. These say they are NOS F 41 shocks. Right now the price as of this posting are $150.00 with a little less than an hour to go.
http://cgi.ebay.com/ebaymotors/1965-...QQcmdZViewItem Here is another set for around the same price. http://cgi.ebay.com/ebaymotors/1963-...QQcmdZViewItem |
If no tag on front coils, measure wire thickness. F41 coils are thicker than standard BB suspension, should measure 11/16ths. Look for forged casting number 3829265 & 3829266 on rear shock mounts, if there you have F41, if not it will be standard suspension. |
Checked the rear shock mounts and they are 3829265 and 66 and the front springs are 11/16" thick. Thanks for all the help. Now I have to go out and spend $4000 on a set of shocks. Mike
This is not my ebay listing, but figured I would post it to help out. These say they are NOS F 41 shocks. Right now the price as of this posting are $150.00 with a little less than an hour to go. http://cgi.ebay.com/ebaymotors/1965...1QQcmdZViewItem Here is another set for around the same price. http://cgi.ebay.com/ebaymotors/1963...QcmdZViewIt em Thanks. |
they "might" be F41 shocks but are they correctly dated? that's where the money is. The Ebay ad for the second set do not include part numbers or date codes.
I bought a jack at Carlisle. I just need a jack that would work. Ended up with a mid 70's unit. If I had bought a correctly dated unit I would have been up for 3 times the price. the F41 shocks are a lot rarer than a jack and getting correctly dated units even harder. |
Ahhh gotcha, thanks for explaining it.
