Refresh my memory - where's the water temp sender/sensor on a '79?
I see one on the rear (driver's side) above the oil filter, which I assume is the oil pressure sender.
There's another sender forward of that, or is it up higher on the intake manifold, near the water inlet? |
Re: Refresh my memory - where's the water temp sender/sensor on a '79? (Neo Fender)
Look on the drivers side head between the # 1 and # 3 plugs.
tom... |
