Brakes Brakes brakes.
I am outrunning the performance of the stock C6 brakes when running on R's. I already have brake cooling So the question is what brake kit.
Brembo seem too expensive @ $3000 for a front set. Floating rotors,thats good. 4 piston? Stop tech same as the Brembo @ $3000 front set Wilwood SL6 , are they up to handling the racing environment? They are priced right at $ 1200-1300 for front set :thumbs: Red Devil Brakes offers Calipers for C6 and C5 has anyone tried these they are price well at $2000 for front 6 piston calipers, are they up to the task? Usable on the street? AP? Alcon? Are there any others readily available up to the weekend racing/HPDE environment as well as being usable on the street and at or under $2K for a good set of front calipers/rotors? Any thoughts appreciated...... |
Many guys put on race pads as Wilwood H, Carbotech xp10 or xp11s or Hawk Dt70s, Castrol SRF brake fluid ( the New WIlwood 600 is an option ) and out run and underbrake must BBKS with the stock corvette caliper. The Corvette caliper is better then most ppl give credit for. BBKs may not stop you sooner, but the equipment will last much longer and that is their primary design.
Hard Bars 2 piece rotor may be an option too
Brembo seem too expensive @ $3000 for a front set. Floating rotors,thats good. 4 piston? Stop tech same as the Brembo @ $3000 front set Wilwood SL6 , are they up to handling the racing environment? They are priced right at $ 1200-1300 for front set :thumbs: Red Devil Brakes offers Calipers for C6 and C5 has anyone tried these they are price well at $2000 for front 6 piston calipers, are they up to the task? Usable on the street? AP? Alcon? the other option is to change your braking style, brake a little sooner and use more momenteum though corners. Slow in = fast out ;) Good Luck |
Stoptechs can use the stock master as the piston is the same volume. You need not do front and rear. I have used the Wilwoods hard where the rotors glow red in daylight pictures. I just put Wilwoods on the rear also. LGM has both types. For the price the Wilwoods are great pads are cheap with a great selection for many manufactures.
Wilwood SL-6R & SL-4R with zinc-plated (for the waxer in me) two-piece rotors here. See sig for details.
I don't think MSR is as hard on brakes as some of the tracks I read about here. So, no need to spend more money (as if I didn't spend enough already) for even thicker calipers (which require longer wheel studs - bigger stock wheel spacers) & pads or thermo-lock pistons. You may want to consider what kind of speeds you see at tracks you regularly run and I assume you aren't leaving the Corsairs on full time. |
I don't think MSR is as hard on brakes as some of the tracks I read about here. So, no need to spend more money (as if I didn't spend enough already) for even thicker calipers (which require longer wheel studs - bigger stock wheel spacers) & pads or thermo-lock pistons. You may want to consider what kind of speeds you see at tracks you regularly run and I assume you aren't leaving the Corsairs on full time. Thanks for the answers guys, So best bet is race pads with Hardbar rotors and stock calipers? Or the wilwood SL6. |
I run the full StopTech package. It does not require an aftermarket master cylinder, but does require 18" wheels to clear. Read the Brake White Papers on the StopTech home page, and talk to Jeff (jeffritter@stoptech) for more information. I am very pleased with mine.
