C6 BCM Connector Layout ?
I was wondering if someone has a picture that shows which connector is which on the BCM ?
LIke C1, C2 C3 etc. Any help you can give would be great.... |
Anyone ?
I know I'm resurrecting an old post but I need this info now myself, anyone have this data that would care to share?
Thanks Mark that helps alot. Any shots of the bcm panel showing which connector is which? Or am I asking too much?
This shows two of them. You can usually figure it out by the size/color of the plugs (they're all described on the plug sheets), if not I just look at the wire colors.
Thanks again Mark.
Can you please post a real link - this one says "Source image is unreachable"
