Great updates, you're making very good progress...
Rogman |
not NCRS, but a lot better than what was in here, a flat dryrotted spare, broken carrier
http://sphotos.xx.fbcdn.net/hphotos-...44278985_n.jpg http://a8.sphotos.ak.fbcdn.net/hphot...10644238_n.jpg http://sphotos.xx.fbcdn.net/hphotos-...22179596_n.jpg |
Awesome job! Keep the pix coming. You have an incredible gift.
Found the original pump in a box of parts, the line from the pump to filter is in great shape, I am going to clean and reuse it
http://a5.sphotos.ak.fbcdn.net/hphot...69114102_n.jpg |
Starting to sort out parts, getting a new line kit for the carb
http://sphotos.xx.fbcdn.net/hphotos-...68754118_n.jpg |
cleaned up the original line from pump to filter
http://a3.sphotos.ak.fbcdn.net/hphot...18720214_n.jpg |
One of the times I wish I didnt have giant bearpaw hands..put fuel pump in tonight
http://sphotos.xx.fbcdn.net/hphotos-...94774650_n.jpg |
Fuel lines after wire wheel and the distributor I got from 69MA
http://a1.sphotos.ak.fbcdn.net/hphot...92199924_n.jpg |
Carb line mocked up, will need to rotate the junction block when I make up the line from the filter....
http://sphotos.xx.fbcdn.net/hphotos-...20334806_n.jpg http://sphotos.xx.fbcdn.net/hphotos-...34693539_n.jpg |
I know for a lot of people this is simple, but others may wonder about the process, so posting pics of changing to a tach drive distributor and setting it up to trigger an MSD box.
Old dist in place, marked rotor so can drop new dist in same place http://a2.sphotos.ak.fbcdn.net/hphot...55208625_n.jpg |
Removed module, used MSD wire lead, so now has MSD plug which will connect to box
http://sphotos.xx.fbcdn.net/hphotos-...99888861_n.jpg |
Only way it fits is to mount as I did, taped it just to be sure, the MSD lead kit comes with the white hold downs.
http://sphotos.xx.fbcdn.net/hphotos-...97382660_n.jpg |
Advance kit installed, sometimes the center weight thingy has different size holes so that the advance kit center will not fit, that was the case here, so I used the old one...I have done this in the past with no issues, I set it up with the lightest springs as I want the advance to come in early, car has 4;11's and heavily ported heads.
http://sphotos.xx.fbcdn.net/hphotos-...46256813_n.jpg |
