c6 z51 sway bays upgrade to z06
Anyone done this?
Comments. Especially with Auto X results. |
Haven't done it because in NCCC it moves you to group III.
According to the SCCA 2006 solo rules you can change the front only and still run stock.
13.7 ANTI-ROLL (SWAY) BARS A. For front anti-roll (sway) bars: 1. Substitution, addition or removal of any front anti-roll bars is permitted. 2. Substitution, addition or removal of anti-roll bars may serve no other purpose than that of an anti-roll bar. 3. The use of any bushing material is permitted. 4. No modification to the body, frame or other components to accommodate anti-roll bar addition or substitution is allowed, except for the drilling of holes for mounting bolts. Nonstandard lateral members which connect between the brackets for the bar are not permitted. B. Rear anti-roll (sway) bars: 1. May not be removed, replaced, or modified in any way. 13.6 BRAKES A. The make and material of brake linings may be changed. B. Substitution of clutch and brake hydraulic lines with solid metal or braided metal is allowed on all cars manufactured before model year 1992. C. Alternate brake bleeder fittings such as “Speedbleeders” are permitted. They may serve no other purpose. |
