electrical problem
I discovered a new problem today and I wanted to see if anyone had ideas as to the cause. My coutesy lights will not shut off. no matter if the doors are open, closed, or car is started. any ides?
Check your pin switches at the door jambs, they can loosen up and back out. When the door closes, it doesn't push the plunger in far enough to break contact.
Make sure they are off at headlight switch.The white wires are seeking ground which will turn on lights.Also if the delay relay is bad it will leave lights on.
how can I tell if the relay is bad?
