Full Power Graphic?
Re: Full Power Graphic? (ZR1991)
Yep I havent but I guess CJ has a picture of it on his 90 and I guess 90 is the only year that had it???
Ill let you know once I get stateside and ill try it in mine :yesnod: |
I saw that message before and didnt understand..
What it this all about?? -90 ZR1 you can keep Full Engine Power On all the time, but what was message about? :eek: |
I asked this question before. I guess only 90s have the full power light on the DIC. It is suppose to illuminate on the 90 ZR-1 when the power switch is turned on.
Re: Full Power Graphic? (fastzr1)
It ain't in my '95
Re: Full Power Graphic? (VetBoyZR1)
I think I can clear this up....
On '90 ZR-1's, the Power Key is a 2 position switch. You can have it off, or on. On 91-95 ZR-1's, the Power Key is momentary in that it always looks switched to the "Off" position - It's spring loaded so that EVERY TIME you get in the car, you have to reach down and turn the key. 91-95 have a little green light located next to the key - When lit, this light tells you that "Full Power" is on. GM got a bunch of complaints about the glaring "Full Engine Power" in Amber being lit all the time the power key was on, so they changed it from the DIC to the location by the key. |
Re: Full Power Graphic? (Avi)
That's what i would have guessed. I assume they disconnected the circuit and left the harness. The graphic is gone from my panel as well. I just checked with a flashlight.
I understand the complaint about the light, because I get tired of seeing ASR OFF. The green light is a little TOO inconspicuous, as there have been a few times when I didn't realize I was OFF.
Ohh.. Now I understand.. I didnt know that only -90 ZR1 has Full Engine Power light on DIC. Its cool text.. Like it says " I will kick a**" to people who dont know about ZR1. Full Engine Power.
