Loose Steel Rocker Arm Nuts
During the rebuild of my 350, I installed a set of Crane steel rocker Arms, pivot balls and adjusting nuts.
When I installed the nuts, they did not take much torque to loosen or tighten up. Sinnce, they have become loose on several occasions, requiring re-adjustment which is a pain in the ___. I have never had this problem before. Has anyone experienced this problem? and what was the corrective action taken? I am thinking of using a jam nut over the top of the adjusting nut. Thanks, gm |
replace them with good locking nuts
Yep,, spend the money and get the set screw locking ones.
I had the same problem with my big block and i used the blue locktite on the nut and fixed the problem.
Goose
You have a good idea.
Some times you can't see the forest for the trees. Thankx, gm |
