Can you compound dealer incentives with GMS pricing?
Sounds too good to be true, but just thought I'd ask. I qualify for GM Supplier Pricing through my employer (about @ 10% discount), but do I also qualify for any dealer incentives? I just love the whopping $250 GM cash back special incentive going on now.
So if I can't compound dealer incentives, then it really doesn't matter which dealer I place my order through, huh? Am considering the following: 1YY07, 80U, 316, LS2, MX0, 3LT, QX3, F55, U3U, CC3 |
I doubt it, because most GM dealer incentives exclude Corvette. However if you have a GM card, you can combine your earnings with GMID. I did with my 06 purchase.:thumbs:
It's up to the dealer.
If the incentive is a factory to customer incentive, yes you do get it. If it's a factory to dealer incentive, it's up to the dealer. As someone mentioned, it has to be an incentive that actually applies to the Corvette.
Originally Posted by Corvette Junkie
But not with GM Supplier.
I called GM card several times to confirm that I could use my "copper" earnings with GMID, and in the end they were honored. |
You CAN combine other Chevy/GM discounts with a GM Supplier discount as I did on my purchase of my '05 coupe. I combined GM Supplier with a GM Loyalty discount for owning a '92 C4 and the dealer had no problem with both |
I just closed a deal on a 2007 coupe using supplier discount and also got the $250 cash rebate. Every little bit helps. No doc fee either.
John |
