The Grond Chronicles : Reincarnation Part 6 [Dialup; Perpetual Wretchedness]
As always, full details of The Grond Chronicles are at http://www.grond.tv
Precis : Shattered Hammer, soon to be Reforged… Part 1 of The Grond Chronicles : The Reincarnation, dealt with stripping the body panels and removing the entire drivetrain and engine. Details are here Part 2 documented the complete engine teardown and looked like a scene out of Chernobyl. Details are here I then auctioned off 2 of my melted pistons to benefit St. Jude Childrens Hospital on the Corvette Forum. That auction raised $2400 for the sick kids - here Part 3 covered the interior demolition. Details are here Along the way, I bought this – a JL Audio 18inch subwoofer. And a few amplifiers… :D Part 4 documented how to install 4.5inch tubs on a C5 Coupe and a weld-in custom 6 point chrome moly roll cage (cage courtesy of Cajundude). Details are here At the end of Part 4, I bought a brand new bare LS2 block - here Part 5 covered the build of the custom fibreglass enclosure for the mega subwoofer, false floor, the beginnings of the amp racks, and targa top storage. Details are here During Part 5, I became a Supporting Tuner - here Part 6, that you are reading now, will detail the installation of a ratchet shifter connected to a 4L60E transaxle transmission. This is a C5 first! Parts 7, 8, 9, etc. I will reveal as time goes on. This project will stretch for several months – at least until March 2007 - so please pull up a chair, open a cold one and get comfy. So without further ado, here are the pics. EG :cheers: Is there any interest in this as a turnkey mod? Currently this is a weld-in permanent mod but I am thinking of offering this as still a custom mod - but turnkey and bolt-on - new shifter, housing, custom console and shift boot. It will look stock when completed and only one x 1 inch hole will need to be drilled in the tunnel - no cutting and no welding!! Any Interest??? Please post in this thread if you would be interested in this mod for your automatic C5... Let's start with a B&M Pro Ratchet Shifter http://grondpix.com/reincarnation/shifter1 - 1.jpg I was told categorically by B&M that this shifter will NOT work in a Generation 5 Corvette. I had the same answer from Jeg's, Summit Racing et al... http://grondpix.com/reincarnation/shifter1 - 2.jpg So naturally I am going to try and make it work.. http://grondpix.com/reincarnation/re...tion21 - 4.jpg Started by fabbing up a bracket or two http://grondpix.com/reincarnation/re...ion21 - 28.jpg And spending a lot of time fine tuning... http://grondpix.com/reincarnation/re...ion21 - 29.jpg But after all that work, I realise too late that the 6 foot cable that ships with the shifter is w-a-y too short... http://grondpix.com/reincarnation/re...ion21 - 30.jpg So ordered a 12 foot cable from Jeg's (cost $60 :eek: ) http://grondpix.com/reincarnation/re...tion23 - 1.jpg OK. Let’s get to work on the shifter!!
Originally Posted by EnglandGreen
Many folks have asked me to post a new thread every time I post updated pictures. That will not work, and here are the reasons why :
I am trying to keep it to 1 thread per major modification from start to finish. Unfortunately it never quite works out that way and always goes way off topic all the time. Even so, I don't want to break them up into dozens of tiny threads as it will make it too hard to have continuity with each major mod. So please set your "View" settings at 100 posts per page. Problem solved :yesnod: UserCP (User Control Panel) - top menu http://forums.corvetteforum.com/usercp.php? Then "Edit Options" http://forums.corvetteforum.com/prof...do=editoptions http://grond.tv/cfoptions.jpg |
OK. Back to the shifter. Where was I?
Oh yes, made a template and offered it up http://grondpix.com/reincarnation/re...ion31 - 30.jpg If I can get it at this height, this will look way cool http://grondpix.com/reincarnation/re...ion31 - 31.jpg http://grondpix.com/reincarnation/re...ion31 - 32.jpg Transfer the template to steel... http://grondpix.com/reincarnation/re...ion31 - 34.jpg Drill the mounting holes... http://grondpix.com/reincarnation/re...ion31 - 35.jpg And cut it out http://grondpix.com/reincarnation/re...ion31 - 36.jpg Smooth the edges... http://grondpix.com/reincarnation/re...ion31 - 37.jpg And try it on for size... http://grondpix.com/reincarnation/re...ion31 - 38.jpg Good fit... still concerned about torque tube clearance though... http://grondpix.com/reincarnation/re...ion31 - 39.jpg |
The moment of truth (tunnel viewed from below)
http://grondpix.com/reincarnation/re...tion32 - 1.jpg http://grondpix.com/reincarnation/re...tion32 - 2.jpg Remember, this is a permanent mod!! http://grondpix.com/reincarnation/re...tion32 - 3.jpg First tacks http://grondpix.com/reincarnation/re...tion32 - 4.jpg This is the biggest downside to working alone. I end up having to jury-rig all sorts of Heath Robinson (Rube Goldberg to my American friends) contraptions just to do simple tasks. Made this stand to hold the shifter base while I tacked it in place - or course, it caught on fire... http://grondpix.com/reincarnation/re...tion32 - 5.jpg Now for the side support http://grondpix.com/reincarnation/re...tion32 - 6.jpg Tacked in place http://grondpix.com/reincarnation/re...tion32 - 7.jpg OK. Ran some beads on this bad boy http://grondpix.com/reincarnation/re...tion32 - 8.jpg And on the top. It isn't going anywhere! http://grondpix.com/reincarnation/re...tion32 - 9.jpg |
I ended up having to mount it higher than I would have liked
http://grondpix.com/reincarnation/re...ion32 - 10.jpg But the torque tube clearance was just too tight http://grondpix.com/reincarnation/re...ion32 - 11.jpg It is extremely solid!!!! http://grondpix.com/reincarnation/re...ion32 - 12.jpg Relieved the console for clearance http://grondpix.com/reincarnation/re...ion32 - 13.jpg I was going to make a custom console anyway, so this does change not represent any more work http://grondpix.com/reincarnation/re...ion32 - 14.jpg Let's see how it looks populated... http://grondpix.com/reincarnation/re...ion32 - 15.jpg Sweet!! It clears the AVIC N2 by a mile! http://grondpix.com/reincarnation/re...ion32 - 16.jpg I am very pleased with how this mod has turned out http://grondpix.com/reincarnation/re...ion32 - 17.jpg And the feel of the shifter... Rapture!!!! http://grondpix.com/reincarnation/re...ion32 - 18.jpg Sand, clean and Black rattle-can http://grondpix.com/reincarnation/re...ion32 - 19.jpg Just the rubber weatherproofing to mount. It looks stock! http://grondpix.com/reincarnation/re...ion32 - 20.jpg |
Placeholder 1
Placeholder 2
Placeholder 3
Placeholder 4
Stephen, there's dust on your drivetrain...perhaps it's time to use that stuff, afterall, Rodney built it for your car, not your garage :crazy: |
I find it easier to load up each reply complete in a seperate tab and then click, click, click, submit each reply in succession...none of this placeholder crap while we all :toetap: :lol:
Never had anyone sneak a reply in between. :cheers: |
Placeholder 2
Placeholder 3
Placeholder 4
Talk aboot getting your post count up:rolleyes: :rofl: |
Originally Posted by Stangkiller
I'm a sneaky bastard though...i got that last post in just incase there was to be a place holder 5 :lol:
That's lame! Post pictures! :toetap: :lolg:
Stephen, there's dust on your drivetrain...perhaps it's time to use that stuff, afterall, Rodney built it for your car, not your garage :crazy: :rofl: :willy: :crazy: CRAP!!! I just made page one of an E.G. post... (feel like I accomplished something)... Oh, and even better: :D http://i37.photobucket.com/albums/e6...482badlink.gif |
CRAP!!! I just made page one of an E.G. post... (feel like I accomplished something)... Oh, and even better: :D http://i37.photobucket.com/albums/e6...482badlink.gif Stephen, the Shifter's looking great! As i've said before, i can't wait to drive it! I hope that metal i picked up is working out well. |
Be prepared...he's going to advise you to run 100 posts per page :leaving:
Can't wait to see this thing done Stephen... DANG! |
This is the biggest downside to working alone. I end up having to jury-rig all sorts of Rube Goldberg contraptions just to do simple tasks. EG Once you get a lift some of the things will become easier when working alone |
EG Looks good especially once you painted shifter bracket:thumbs:
Stephen, can't the "arms" those ends of the shifter be cut off for a better fitment?
http://grondpix.com/reincarnation/re...2%20-%2015.jpg |
Never had anyone sneak a reply in between. :cheers: All pics are now posted with commentary anyway :yesnod: |
This thread is worthless without pictures of the fire.
Stephen looking for the extinguisher.>:willy: WooWooWoo! |
