Steering wheel Mounting screws
I have some stripped out screws in my steering wheel hub. Does anyone know what size and pitch screws mount the steering wheel for a 67 vett. I am going to install heli coils once I get the right size. Thanks Don
I don't know the size off hand. Take one to your Flaps and they can match it to the correct helicoil.
10 - 24 x 1/2" countersunk phillips head.
That's an odd pitch size. Thanks for the info.
Haven't checked price or availability, but wouldn't a new hub be easier?
Dr Rebuild does have hubs but I didn't see a price listed.:rolleyes:
But his 53'-62' hubs are $130. :ack: |
Offhand, I'd say you have darn little room for a Helicoil on the edge of the hub. Better bet would be to drill & tap the bad holes 1/8"-3/16" deeper if you have the room.
#10-24 tpi an odd size? Not around here.:toetap: On my hub the flat head phillips screws were always coming loose. Solved that problem with hex socket flat screws. |
It's only one screw for now so I am going to install a helicoil. I think there is plenty of meat for a coil. I will check with Ace hardware for the SS screws Thanks. Don:thumbs:
