TTiX Pic Request............
Would someone please post a Pic of their engine bay, I was wanting to see how clean this Kit (TTiX) looks. I'm in the process of going from a SC to a TT kit in the near future and I'm trying to make my mind up.
Thanks :cheers: |
mdhmi,
Man, thanks that looks very clean, I just saved it to my pic's. |
How about underneath?
I've been lucky so far, knock on wood. :rofl: I'll be giving you a call in the near future, you can bank on that. |
I actually meant I was looking for some pictures of the X kit from the bottom side.
Originally Posted by IN DEBT
My Bad!:leaving:
No problem. I can see why you thought I was talking about your drivetrain. The TTiX kit should come with our phone number on the outside of the box.:D |
Phil This is not finish welded or coated. http://www.turbotechnologyinc.com/te...derside/02.jpg http://www.turbotechnologyinc.com/temp/TTiX_Dual2.jpg |
For those of you with ground clearance concerns.. the TTi kit has nothing that sits lower than the oil pan.
http://www.usionline.net/IMG_1434.jpg Here is a picture of my finished exhaust. I chose to use a Corsa X Pipe and fabricated the mid pipes from the X Kit DP's to the X pipe. This also shows the coated and finished parts. http://www.usionline.net/IMG_1529.jpg I have A LOT more... :D |
Originally Posted by FactoryRaceCar
Nick can you post some underneath shots of the front cross member? I just need to see if the pipes will rub against 18X10 front wheels with 275/35/18 tires
Thanks! You can flatten the pipe on the passenger side to get around this. I have stock size tires on my Z and did not flatten the pipe, it is nothing to worry about and easy to work around either way. |
Thanks! |
Originally Posted by BLOWNZO6
Hrmm... don't know how my post quoting yours ended up being above this one... :willy:
Thanks! See :willy: :rofl: :willy: :rofl: |
Proof I am always a day late and a dollar short :leaving: :D
Folks... I think I have had too much to drink...
Thanks! |
Thanks! |
