lowering 87"
Does anyone know what tools I need to safely unspring the leaf springs? Any advice?
a floor jack.
Get the car up in the air, remove the tires, then support the spring and release the retaining bolt on that side. Lower the jack will untension the spring. Very simple. Reverse for installation. |
Originally Posted by bogus
(Post 1558272431)
a floor jack.
I can't tell by your thread title and then post what you are really trying to do. Are you trying to lower the car, or just remove the springs for replacement? I would not drive around with the springs just disconnected from the suspension. You need to install longer bolts to lower the car properly in the rear.
Originally Posted by scorp508
(Post 1558272832)
(Post 1558272832)
You know that you can't drive around with the rear spring disconnected. The tires will contact the bodywork and cause all kinds of damage. Aaron |
Originally Posted by AKS Racing
(Post 1558278082)
Scorp,
You know that you can't drive around with the rear spring disconnected. The tires will contact the bodywork and cause all kinds of damage. Aaron Thats why I said I would not do it! Scrape'age everywhere. :) |
(Post 1558279864)
You are right about that. Lowest of low!!!!
