Complete Widebody Conversion Information and Parts list
Here are some cutaway sheets of the front and rear parts
Also i am putting up a complete parts list and step By step Instructions will follow. Here are the sheets http://www.sshomecinema.com/widebodyfront1.jpg http://www.sshomecinema.com/widebodyfront2.jpg http://www.sshomecinema.com/widebodyrear.jpg |
Also Wanted to mention that ipurchased ALL MY PARTS FROM BOB WENDORFF AT FICHTNER CHEVROLET ( FORUM VENDOR)parts@fichtnerchevrolet.com
BOB was great and helpfull every step of the way. ALL PARTS FOR REAR CONVERSION Rear quarter panels Left 15932449 Right 15932447 Rear Fender liners Left 15874588 Right 15874589 Rear Brake scoops inner Left 15842370 Right 15842371 Rear brake scoops outer Left 15787683 Right 15787684 Rear inner brake ducts Left 15842373 Right 15842372 Gurney Flaps (Mud Guards) Left 15818636 Right 15818637 Seals 15881432 Need 2 Pushpin fasteners 11519444 ALL PARTS FOR FRONT CONVERSION front Carbon Fiber Fender panels Left 15779342 Right 15779343 Front Inner Fender liners Left 15827791 Right 15827792 Front Outer Fender liners Left 15834373 Right 15834374 Front Nose Clip 15915335 Chin Spoiler Lower 15834249 Front Grille Outer 15857168 Front Grill Inner 15822871 Various Items Nuts and clips 11517700 Need 3 10330821 Need 1 10330822 Need 1 11609411 Need 8 10342936 Need 1 10342937 Need 1 11609489 Need 6 11589259 Need 6 11609489 Need 12 11515638 Need 12 11609487 Need 5 11609871 Need 2 Seals 15881433 Front Nose Seal 15774161 Need 2 1 for each fender Also if you need a new c6 emblem for the new nose 10370896 Also note on front You will reuse brake duct tubes and most clips REAR REMOVAL INSTRUCTIONS 1. You need to jack the rear of the car up and place on jack stands 2. Remove rear tires 3. Remove inner wheel liner screws and clips 4. Remove the push pin adapters holding the lower valance to the wheel well liner 5. Remove the clips and the screws holding the brake ducts 6. I removed the 1 screw along the bottom of the rocker panel 7. Remove license plate as are two plastic square drive screws are behind it 8. Remove all torq's screws running alone the edge of the fender and rear panel when you open the trunk. There is a bunch. I also removed the lower two on each side of the roof pillar. There are some inside when you open the door as well (6). 9. Remove the wheel well liner once fender is 90% loose it should come out 10. Remove all tail lights 11. There are 2 bolts that you have to remove from the rear fender panel and a metal bracket by reaching inside the two outermost tail light openings. 12. There are nuts that need to be removed from the inside of the wheel well from the same bracket the screws are attached to from above step. There are 2 nuts and a nut and a bolt holding the fender and the rear clip together on each side. 13. Remove 2 screws above exhaust tips to release rear valance as wheel as the square drive screws behind the plate. I just used a skinny flat blade screw drive for this. 14. You will want to disconnect all lights at this point. Reverse, tail lights, third brake and license plate light as well as side markers. 15. Pull lower part of rear valance up and the bottom will come loose. Then you will have to lift the rest above the lip where it screws inside the truck. 16. their is now 2 push in clips that need to be removed from the metal strips that line up all the parts in order to remove the quarter panels 17. Now open the door. Lift from the bottom in the door opening and watch the part that goes under the roof bar. Should lift right off 18. Undo the 3 screws holding the gas door in place. On the other side and set aside. That is the only difference on driver’s side. End Result http://www.sshomecinema.com/rear6.JPG |
Should make many members experience much easier, thanks for taking the time :thumbs:
I want to thank you for posting this and your thread on your wide body conversion. It's amazing. Its going to help me a lot as I get ready to get the needed parts and start my project this spring. :smash: Thank you for helping us out.
Added Above to keep info at top
Thank you.
Instead, just sell me your car.
Originally Posted by MAJ Z06
(Post 1558407126)
wide body
Like I said before. Bill has done a fantastic job in helping out the other forum members with their projects.
Once again, there are many people on the forum who give alot of their time to others by taking that extra step. Without mentioning all of them, we forum members appreciate you all! Chucky7 |
Originally Posted by chucky7
(Post 1558407473)
Once again, there are many people on the forum who give alot of their time to others by taking that extra step. Without mentioning all of them, we forum members appreciate you all! Chucky7 Thats what makes the forum great :cheers: You can learn so much from so manny people here! Just glad to contribute and help anyone here :thumbs: |
Wow! This is Awesome! Great Job! :thumbs: :cheers: :cool:
Just what I was looking for, thanks! :thumbs:
Now... do you need a nice Florida vacation to help do another one? :lol: |
Originally Posted by Joe_G
(Post 1558407655)
Excellent job Bill! I wished you were about a month in front of me and my WB project. (Well make that 2 months with my Fred Beans fiasco)... either way I could have really benefited from your detailed and informative posts!
Rock on dude!!! :thumbs: :thumbs: How did your paint come out? Bone |
I can't wait to see your end results after paint. When can we expect the pictures?
Bob |
Great write-up, Nice Job! I can't wait to see the final product.
Thanks Bill. :thumbs: Paul :cheers: |
Thanks Bill.:thumbs: :thumbs:
Originally Posted by TN 2005 C6
(Post 1558410362)
Bob We are finishing the clear today and then reassembling the panels temporaly , then 3 days of colorsanding the entire car. Then it will take me a week to put it all back together. I have a ton of pics of the paint process. I will upload them later |
Originally Posted by burtonbl103
(Post 1558407669)
I am actually considering doing a few more in the NE area after mine :willy:
Burton i asked for this last week and you came thru with this awesome write-up. thanks for the great step by step write up. this will give alot of people the knowledge they need before proceeding themselfs. if your ever in the Inland Empire of so cal. let me know i owe you a few :cheers:
