Looking for crankshaft #3967811
Can anyone tell me where I might locate a Carnkshaft #3967811 new or uncut?
Thanks |
Re: Looking for crankshaft #3967811 (BAD-L88)
There's a guy here in Houston that buys and sells any type of crank. He has dozens of bb cranks and is at most of the swap meets. They are very nice. Personally, I couldn't think of a worse thing to have to haul around and unload all the time. I have his card at home. I'll look for it and post it when I find it.
bl :chevy |
Re: Looking for crankshaft #3967811 (Bryan Lee)
All right, I found it.
His name is David Pierson. Phone is 281-586-7076 hth bl :chevy |
Thanks Bryan,
I will try him in the morning. |
In 1991 I purchased a brand new L-88 crankshaft to put in my L36 427 rebuild. I wanted the extra cross drillings that the 3967811 crank offered. At the time I paid $562 for the crankshaft. I still have the receipt. You may try your local Chevy dealer as it may still be available. Check the latest edition of the Chevrolet Power Book.
Re: Looking for crankshaft #3967811 (BB68Vett)
Good forged cranks are still available through GM. They need to be straightened before you use them.
ALL 427 cid crankshafts (3.76" stroke), including the GM #3967811, are now GM-discontinued. Most 454 cid (4.00" stroke) forged crankshafts for Mark IV, Gen 5, and Gen 6 big blocks are still available.
Check out Eagle and other brands. They have a variety of stroke and balance combo to choose from. All their cranks are 434 steel and are cross drilled and polished for a mere 700 plus bucks.
I for my 502 build up I chose the 4.25" stroke, internal balanced crank. Had the rotating assy. balanced. The shop said this was the best crankk he's seen in all his years. It had almost perfect balance. Very little drilling to get it perfect. |
