who makes the Brightest LED 3157 bulb?
I have acrylic blackout front turn signals and I'm not happy with the brightness of my front running lights. I need an amber 3157 LED bulb that really cranks out the lumens.
what do you reccomend? thanks. |
these say they're the most powerful 3157 LED bulb EVER MADE!
SMT Tower 18 High Powered Wide Angle SMT LEDS These Bulbs have Advanced Surface Mount Technology LEDS 15 high powered SMT side facing LEDS - 3 high powered SMT forward facing LEDS The most powerful 3157 led bulbs made Only 25mm diameter x 52mm overall - fits all stock housings http://autolumination.com/3157_3156.htm |
Silverstar 3157/4157AST - Walmart, about $16 a pair
Originally Posted by jbondfl
(Post 1559652154)
given the prices for the autolumination LED bulbs, do you all think that i would get better light by replacing the corner light Housings with euro style (clear) housings, or by replacing my standard LED 3157 bulbs?
If you have blackouts, you are going to need to stick to incandescent bulbs. The LEDs still can't compete with them as far as output when just replacing them using the same socket. Then only way they can is to use a lot of them, and that usually means replacing the housing like the LED tail lights.
Originally Posted by TheRadioFlyer
(Post 1559653168)
If I went with clear housings I think I'd go with the LEDs for the cool factor. |
thanks, I think i'll get the euro housings first for a better reflective pattern and if that doesn't make it look better, i'll get the high flux bulbs.
(Post 1559652154)
