Hyundai ??? But What the Hell
Can the Pistons ('97 GL 4 banger) be removed without taking off the head? By just removing the pan only... I don't see how, but I'll ask anyway... Kids car has no compression in #2 & 70# in #3, 1 & 4 are Ok... I think the compression ring went south...
It can be done, but dropping a crank and rebuilding everything from under the car is a huge pain in the buttocks.
Might also be valves. |
Originally Posted by mvftw
(Post 1559670063)
other cars has it`s own page!! ...redvetracr |
Originally Posted by redvetracr
(Post 1559670272)
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
Originally Posted by Durango_boy
(Post 1559670134)
Originally Posted by Twin_Turbo
(Post 1559670697)
How are you going to get the pistons past the main webbing bulkheads? Have you ever done this?
I did something similar on an '01 Hyundai motor. You? |
(Post 1559670272)
My experience is with renault, fiat and alfa romeo 4 bangers but it shouldn't be too different, all are 4 cylinder in line dohc engines and all being as compact front wheel drive as they can be they are very similar in design and have partially overlapping bores and bulkheads like any compact engine design.
(Post 1559670063)
Originally Posted by big_G
(Post 1559671075)
More likely valves or head gasket than rings, IMO.
Originally Posted by MYBAD79
(Post 1559671214)
yup.... pull the head first. These 4 cyl engines are relatively easy to work on......
Yeh, sure if you got tiney, teeney weeney little hands like a China Doll.... get my damn hairey assed mitts in there and you got NO room for even a cockroach.... I HATE FWD to work on, a real PIA>.... :crazy: :lol: :eek: :smash: :willy: :willy: :ack: |
Just change the rubber band, and drive off.:lol:
(Post 1559671075)
That's what I'm thinking it is and pulling a head is a lot easier. |
You guys need to show a little more compassion. I mean after all, his kid's favorite squirrel just died.
:toetap: |
More likely valves or head gasket than rings, IMO |
(Post 1559673400)
I don't think so because...I should have said this first...it has a lot of blow by coming out the oil filler cap. That's why I think it's in the block (rings) and not the head...
Long story short...you'll find it a LOT easier to change the piston rings from the top, and while the head is off you can have it inspected and worked over if needed. |
Originally Posted by TimAT
(Post 1559672846)
:toetap: |
(Post 1559673444)
If it has that much blow by, it must have ventilated a piston.
How would you compress the rings to put the pistons back in from the bottom? |
With duct tape which then also acts as a super special ring seal!
