C6 ZO6 VaraRam Induction Kits now available
We have the C6 ZO6 'VaraRam' Ram Air Induction Kits available. These are in stock. These are brand new, never before offered.
As you know the Standard C6 Snake Charmer is good for 40+HP and 3 tenths in the quarter. Then add in a Throttle body spacer for an additional 5HP gain. These kits will include a Throttle body spacer in the package price of $419. Remember to enter SS2007 at checkout for 10% off! They are available for purchase here: http://www.rpidesigns.com/shop/item.asp?itemid=920 http://www.rpidesigns.com/images/z06vara.jpg Please email us with any questions or comments. Thanks! :thumbs: |
I must say that it seems pricey...Can you break down the items and some data to back up your HP claims on a ZO6...
Thanks, Greg |
would like to see it installed on a car and what kind of modifications you must do to place it on your car as well
wow, vette tax in full monty there :eek:
Originally Posted by BLU-BY-U
(Post 1559856833)
Originally Posted by UBNZO6D
(Post 1559850367)
Thanks, Greg |
what is the difference between the z06 and c6 part? I have the z06 front end on my c6 and it fits fine.
I'll need a whole lotta proof before purchasing.
Originally Posted by john_sblendorio
(Post 1559864864)
Originally Posted by RPI Designs
(Post 1559844198)
:thumbs: |
Originally Posted by A427MAN
(Post 1559875590)
Wow! 45+ hp from an intake! No, I didn't know...seems unrealistic! Do you have any proof?
Dyno graph from independent shop please:toetap: |
(Post 1559875590)
Not being a doubting thomas, but I've never had an intake give 40+hp in any other vehicle.
I anxiously await the dyno results.:rolleyes: |
(Post 1559875590)
http://www.vararam.com/magazine-pics/gm-info.jpg Here are the results from the GM-High Tech article done of the C6 unit: http://www.vararam.com/gmhightech.html Since this unit is so new we have posted the above, when more information becomes available we will post. Thanks! :cheers: |
Originally Posted by Futfixr
(Post 1559906991)
I anxiously await the dyno results.:rolleyes: The VR-SC1, After 1 full year of R&D the all new C-6 Snake charmer ram air induction kit is finally ready for the street. The snake charmer is a heavy development of the original C-5 B2 unit. We used information gathered from 12 special B2 Race units that we constructed for racing only, these units featured many different internal aerodynamic packages and filter combinations, to maximize peak CFM and time to peak manifold pressure. We have emphasized too many customers and racing teams that its not just peak pressure but the time to peak manifold pressure that we look at, this occurs at shift recovery, down in the meat of the power curve. This helps for shooting off of corners, general driveability and overall peak performance, this shows up in the form of Torque& Lots of it. Like all VR units the snake charmer was not designed for the dyno (pulling air) it was designed for ramming as such the aero package and shape of the unit are designed around this. The philosophy is simple; design for the most efficient aero package possible at all speeds ranging from 10 mph- 180 mph. The snake charmer is over 108%-123% efficient depending on the filter used. The Filter: The filter for this unit was custom designed in house and produced by a subcontractor for Donaldson. It is a pleated unit that is washable and reusable, but that is where all similarities end, the filter features deeper pleats and more pleats per inch than other filters and the peaks and valleys have been opened to further increase flow capacity per square inch. The end result is a very compact high flow filter that will out flow K&Ns of similar dimension by over 30% while actually giving better air filtration, you simply have more filter area that is effective area not dead space. We used the latest in fluid dynamic software to check the flow path of the snake charmer; we say check because the snake charmer was originally designed by hand by company president Patrick Ledford. The flow is so well balanced into the mass airflow meter that at full speed 180 mph+ the airflow is within 1 mph across the entire circumference of the entrance leading into the air meter, the factory tube is not that good! Rainwater will not affect this unit, nor will down pours, you will have to submerse the nose of the car. Construction: The unit is formed using two construction processes, the upper is roto molded to ensure a seamless internal aero package leading into the air meter. The second, the lower scoop is vacuum formed, this has been done to allow us to alter the scoop and its aero-packages to suit specific applications, giving us more flexibility and performance in street or racing use. This ensures maximum performance at all times. Performance Guarantee!! So now the how much power will you get question- standing on a dyno without using any special programming you should expect 10-15hp from any cold air kit,but once moving the VR will put all the lost MAP pressure back into the plenum yielding another 17hp by 60mph 19-20by 90-100mph and the way we rate our kits is through a mile Your total power through a mile is about another 22hp plus the dyno hp of 10-15hp,so, on the low side, 32 Rear wheel hp, high side 37 Rear wheel hp. That's 39- 42hp at the fly wheel through a mile. This power shows up in the testing performance of the unit where we see gains of the following: 3.5 -4 tenths off the mile +3.5-4mph+ added to the mile trap speeds +7-10MPH to the cars top speed That is serious performance considering that is right out of the box, we will continue development for further performance, but we have maximized the factory programming so more may be possible with custom tuning and we are working with tuners and racing teams now on such programs, so look for these in the future with a VR program or upgrading to a VR programmer if you already own one such a programmer |
Originally Posted by El Puto
(Post 1559906234)
As air is forced though the VaraRam, the power is increased. Please see time slips from above and the GM High-Tech article done on the unit. Article here: http://www.vararam.com/gmhightech.html Thanks! |
(Post 1559930030)
A dyno would not show the gains as the results are shown in the real world. Please remember this is an air induction unit and horsepower gains are shown with the 2.5 - 3 tenths drop in the 1/4 mile.
As air is forced though the VaraRam, the power is increased. Please see time slips from above and the GM High-Tech article done on the unit. Article here: http://www.vararam.com/gmhightech.html Thanks! Thanks for the info. i'm going to call Horsepower Sales in Pompano and see when they will be available |
I had a Vararam in my C5 Z06 and it rocked.....I am sure it will be just as good in the C6 Z06 :thumbs:
Originally Posted by GaryZ06
(Post 1559944263)
Don't you think????? Tom |
Does the bumper need to come off? what all needs to be done to install? Im looking to purchase but these questions will help my decision greatly.
R |
