Where To Buy X Pipe For Lt1 ?
I am going to have an X pipe installed to replace my resonator. Where can I buy an X pipe to make the install as easy as possible ? Thanks
I thought about having an exhaust shop fab something up but I don't want to get ripped off. Ideas on this route ?? |
New one's are about $75 from Magnaflow.
:thumbs: |
Originally Posted by Carpenter
(Post 1559864372)
:thumbs: |
buy the 3" and slip it over your 2 3/4 tubing.
Originally Posted by 96 lt-4
(Post 1559865516)
Originally Posted by ubnpast
(Post 1559867953)
Alot of gap to be welded in?
I just ordered a 3" magnaflow "X" pipe from a local performance shop for $80.00. Can't wait to install it. I hope it makes the exhaust sound more agressive.
Bernie |
Originally Posted by BerniesVette
(Post 1559870942)
Bernie |
I may have to go with eliminators if this doesn't give me the sound I am looking for. I do want to keep the LT1 tips tho!
Bernie |
(Post 1559871820)
Bernie |
I can have the tips cut off and welded on if I remove the mufflers. Much cheaper than ordering everything.
Bernie |
If you are looking for an X-Pipe that is really made correctly for your car, you need to get one from Dr. Gas. They are not cheap but they are right.
To late, I bought a 3 inch "X" pipe yesterday.
(Post 1559872800)
Bernie Joe |
Joe,
I'm just cheap and like doing it myself. Also I have heard the LT1 tips other manufacturers use don't have the same quality as the stock tip. Bernie |
AHHH! I see! Well if I had a welder and a pipe bender I would love to do it myself as well! But it looks like Im going to be taking your root and how a muffler shop weld me up some deletes and utilize the stock tips!
Joe |
Saving money when you can helps with those expensive mods you want to make!:cheers:
