Budget Drag Shocks (C5)
I followed the advice of another CorvetteForum member about putting budget front drag shocks on my C5 (thanks 123sugey) :thumbs: Here's the rundown for those who might be interested in this sort of thing:
Bought 2 Lakewood 90/10 drag shocks (part # 40101) and a set of Mr Gasket 3 1/2" shock extensions (part # 1290); grand total was right around $100 (vs. ~$500 for C5 specific adjustable shocks) . These are somewhat "universal" shocks that can fit quite a few different vehicles, and come with an assortment of mounting hardware, depending on your application. I re-used my original upper bushings since they were in good shape and seemed better & beefier than the little universal ones provided with the new shocks. I also used the following "shop supplies" during the install: a couple of extra washers for the lower control arm mounts, along with some silicone grease for the bushings and a little loctite on the extensions. Overall, the installation went fast & easy...the original shocks are pretty stiff and required a bit of wrestling to remove, but the Lakewoods went right in. Now, onto the big question...can you actually drive around on these things? I got the more aggressive 90/10's, which are not recommended for street use, and I'm glad I did. (70/30 versions are also available...Lakewood claims they are okay for "street/strip" vehicles.) This car is my daily driver, and I have been testing them out during normal street driving over the past few days; no track results yet. My front swaybar had already been removed, but the 90/10's are still very driveable. I'm not a corner jockey, but I'd bet that my car still handles better than 90% of the cars on the road, even with drag shocks and no swaybar. It rides a little softer in front, but still drives and corners great. The front end really doesn't lift much at all unless you really nail it from down low, but it settles back down nicely. It isn't floaty nor bouncy, and corners just fine. If any South Florida guys are considering this mod but are concerned about the driveability, get with me at any of the Moroso or Countyline Challenge events...I'd be happy to let you drive the car and see for yourself. Rob |
Hey Rob thanks for the tip!
I can add for removing the stock shocks, instead of wrestling I used zip ties. Wrap them around each other, keep adjutsting a little at a time and before you know it is is compressed enough to get it out. As far as street drving with a 90/10, sorry I don't have experence with that but I am sure someone can chime in. Please else us know how it works out at the strip and on the street. |
FRC ROB......... I'm glad you installed them !!
They do work great on the street. I'm not for flying around corners either but, like you said the car will still outperform most other cars still. THIS MOD SHOULD BE LISTED UNDER " ALMOST FREE MODS " :lol: Nice write up too......... |
Well, its been a few weeks, and I've now got some track results. This car is my daily driver, and I have no handling issues to report. As I mentioned before, I am not a corner jockey, but for regular commuter driving (city and highway), these shocks are fine. At the track, the car is more consistent. Although I have not yet bettered my personal best 60' time, the grouping is much tighter than before. If you spin the tires right off the line, I don't think any shock in the world is going to help you. However, as long as I'm hooked up out of the hole, it stays hooked up and the suspension does not "unload" going past the tree like it used to. These are a great bang for the buck mod for C5 drag racers :thumbs:
I went from 1.70 best 60' to a 1.40 with new m/t's and lakewoods installed !! That was at PINKS @ Moroso a few months back.
I am going to order my lakewoods on Monday.
I wonder how well the sucess rate is on the lakewoods ,i am with you on the 90/10s as i ordered these myself & also the Mr gasket ext.Part #1290 ,this was 120.00 from Jegs ,Money well spent:thumbs: !! ,i am giving them a shot as well.Along with the mt etstreets & the Novi2k this weekend i will have the et streets on this will be a wild ride ,First time out will be amazing to say the least ,as long as i dont break an outputshaft i will have a smile on my face :iagree: & if i do break i will upgrade
Dont forget to remove the sway bar.
have fun.... |
Originally Posted by 123sugey
(Post 1564069558)
have fun.... Also compared to the expensive shock out there, short of adjust ability what would be the difference between them? Thanks guys. :cheers: |
Originally Posted by Challenger
(Post 1564390751)
I notice in your signature that you cut down the extensions part # 1290 from 3 1/2" down to 2 1/2", what was the reason for this?
Also compared to the expensive shock out there, short of adjust ability what would be the difference between them? Thanks guys. :cheers: tires up 6 inches and they dropback down 10 feet out. Good luck Chris |
I am very interested in this. My car is lowered.....am I going to slam the front air dam on the ground if I have to get out of the gas for some reason?
My car was at stock height. The front rises very quickly yet comes down pretty soft. I never had a problem with bottoming out after getting out of it.
Originally Posted by fsuforever
(Post 1564052512)
Any of you guys have a picture of how you set-up your extensions, sleeves, and bushings?
Thanks Bob |
(Post 1564546691)
Thanks Bob I did not use the sleeves. I used a bushing under the top mount. Sorry, Im in Honduras now and do not have my pics with me. |
(Post 1564550205)
I sold my car 2 months ago but...
why or is it necessary to use the #1290 extensions?
Originally Posted by YO-EL
(Post 1566259401)
Bob!! How you doing my friend. :cheers:
Thanks for bringing this TTT - I missed it long ago. Robert's been telling me for a while that this mod would do more for me that a FAST intake or maybe even heads...I shopped this week for shocks and was SHOCKED to see the price for adjustables. Since I don't road course much at all any more, I think I'll do this mod. |
Originally Posted by Joe_G
(Post 1566263209)
Thanks for bringing this TTT - I missed it long ago. Robert's been telling me for a while that this mod would do more for me that a FAST intake or maybe even heads...I shopped this week for shocks and was SHOCKED to see the price for adjustables. Since I don't road course much at all any more, I think I'll do this mod. Since I suck in the competition arena :lol: and just like to go and play, I could not justify, nor afford the QA1's I decided for less than $100.00 based on all the positive reviews, I would get these. :yesnod: Since I race so often :lolg: They have been on since around Christmas and have yet to make a pass. :leaving: |
