Got a leaky Vert Top? How did you fix it?
I have a 99 Vert that leaks I am looking for fixes. Any help is appreciated.
where is your leak at? Several ways depending on where it is at. Could be a window adjustment, new window mouldings. Mine leaked where the top sets on the windhield. So I went cheap and glued in some weather stripping from HD there and works great. You dont even know it is there.
Good luck :cheers: Brad |
I'd start with the free fix by adjusting the window tip in. PM me if you cant find it with a search and I'll send you the How To.
The other cheap fix is to lubricate the door seals with dielectric grease. If that fails I think I'd try replacing the seals. Thats $$$$ though After that it'll be complicated. |
Thanks guys
I'll try your suggestions this week end. Right now I'm afraid to take the car anywhere if rain might be in the forecast.
YEP - Tip in/out adjustment is a place to start...
I adjusted the vertical seals that contact the rear windows and mine stopped leaking.
You can tweak/bend the seals inner metal support out to create a better seal between it and the window (a little bit goes a long ways). Hope this helps... Later . . . . . . 6 Shooter |
