Track Alignment
this is not for the guy that runs on the street, and does one or two HPDE's per year, but I dialed in -2.2deg front and -1.5deg negative camber on the Z06, and it is perfect. On OEM street tires, we're getting perfect tire temps and wear, and the car is extremely balanced. We were at Roebling this weekend, and I figured -2.2 would be a bit much for street tires, but I happy enough that I'm going to leave it. Will be at VIR for the NCM event in a couple of weeks, and will try the alignment out with some sticky tires.
btw, I really like the new upper control arm mounts on the Z06 rear. It's nice to be able to make adjustments at the upper and lower control arm, unlike the C5 and C6 where you can only adjust the rear on the concentrics. Hope to see many of you at VIR July 1-2! http://www.davidfarmerstuff.com/thsc...s/IMG_2012.JPG |
Did you drop the ride height at all? We couldn't get to -1.5 at the rear with the height set at the factory, -1.3 was the best we could do.
Originally Posted by allanlaw
(Post 1560720197)
You can get better than -2 degrees front and rear with both washers out. Enjoy... Frank Gonzalez |
Our car had 4 washers in front, and 2 washer in the rear. Each washer is almost exactly 1/2 deg, so I took 1 out of the rear and 2 out of the front.
Be doing it this way, you don't have to touch the concentrics on the bottom, and that way you don't mess the castor up. I left the ride height stock, where it works best. I may drop it a tiny bit later, but the suspension is in it's "sweet spot" at OEM ride height. Will have RB rotors and ducts for the NCM event coming up, and likely stick some slicks on. |
Did i understand this right? If I have 1.6 neg camber in the front and I take out 1 washer I will have 2.1?
Thanks Frank and David - I'll keep that tip in mind when I visit with my alignment guy in a couple days . . . :cheers:
Wow David! That's a great discovery! Do you think it would be practical to simply remove the washers for a track set up then replace them for the street? That would sure solve alot of my problems running R6's and runflats.
Cool deal!!!
David, now call me so I can come over and have you set my car up the same way. :D (I left you a voice message) |
Interesting to say the least. My trusted alignment guy claims he could only get -1deg front and back.:willy: :toetap:
Originally Posted by davidfarmer
(Post 1560735123)
yes, 1 washer should take you from -1.6 to -2.1. That is one washer PER BOLT, obviously. It may vary by a 1/10 deg or so, but mine came out to almost exactly 1/2 deg per washer, front and rear.
btw, I do not recommend modifying the alignment back and forth, as you ultimately risk damaging or stripping one of the upper control arm mounts. I always recommend finding a compromise, and leaving it alone. For our car, -2front and -1.5rear is just fine. Drove 225miles each way, plus 4 guys driving at the track, and the wear and tire temps were perfect. |
I didn't know about the washers; I turned the bottom adjusters to full negative on the front, reset the front toe to zero, and left the back alone, and it seemed pretty good to me. I don't have any of that high falutin stuff to measure camber or tire temperatures.
On the tires, I think the grip level of the factory tires is pretty well matched to the suspension tuning, but I wonder if putting on sticky R compound tires might not reveal some shortcomings in the factory suspension? |
The Z06 suspension is darn close to T1 stiffness, and should work great with sticky tires. There are tons of C5Z06's running racing tires, and the C6Z is significantly stiffer IMHO.
The problem with maxing out all of the bottom adjusters is that they are all at different places from the factory, and you never know where you end up withou measuring. I've done exactly what you did, and it's great for track only, but if you want to keep the car on the street you really want to have even castor on both sides. my DIY guide can help measure camber, castor, toe and thrust angle with simple tools most of us have already. http://www.davidfarmerstuff.com/align.pdf |
Originally Posted by outnumbered
(Post 1560738979)
(Post 1560740405)
Horsepucky . . . unless your car is unusually high off the ground. :ack:
I guess a second opinion may be an idea. I do have an enormous amount of trust in my guy but he told my other friend the same thing with his Z51.:toetap: |
(Post 1560735123)
Which slicks? Do you not feel there will be damage to the other parts taking the grunt from slicks? With such a grippy tire, something has to give. Even with my coil-overs I have been hesitant to run anything more than a Hoosier R6. Thanks for your thoughts! :bigears Mike :cheers: |
The C6 and C5 architecture are exactly the same, and we've been running R and slick tires on them forever and ever. I'm running scrubbs that I buy from Bob Chick, but I wouldn't hesitate to run any tire I could find. Remember, the upper and lower control arms take ALL of the later load, not the springs or shocks.
That being said, Hoosier A6's are pretty much the stickiest tire in the world, and the R6's aren't far behind. I use cheap, scrub slicks as practice tires, simply because they are cheap. I may take my Kumhos to VIR as well, but they may be too wide for the OEM brake ducts (haven't tried them). Outnumbered, did you're alignment guy pull the wheels off....I bet he didn't. You certainly are limited in the amount of camber you can get without pulling the wheels, and removing washers, and alignment shops don't usually pull the wheels for alignments. My car had over a degree front and rear camber from the factory. |
Originally Posted by jswatek
(Post 1560738020)
If you add or remove washers (same in the front and rear of each A-arm) for camber adjustment you need to reset the toe. Caster will remain unchanged. Frank Gonzalez |
(Post 1560738979)
Frank Gonzalez |
I posted another post about this per Frank's advice at the track the other day (thank you), before I got a chance to read this post. Just a quick (stupid) question...if I losen the bolts competely (2 per link 4 per wheel), are there any bolts in the frame plates that need to be held so they don't fall away into the abyss when completely loosened? Or are the bolts permanently threaded into the frame and you can just pull out the studs and take out the washers without any concern?
