Snapped off lug bolt from rotor do I need to replace rotor?
I was washing my car this morning and to my shock I noticed that one of the lug nuts off the rear passenger side wheel was missing. After closer inspection I could tell that it was sheard off some how. I plan to take the car to the dealer but wanted some insight from the group if the lug bolt itself can be replaced or am I looking at needing a completely new rotor (Z51) and lastly if a new rotor is required would I need to replace both rear rotors? The car only has 8,000 miles on it.
Thanks |
Not sure about the C6, but typically you should be able to just remove the rotor then press or tap out the broken stud. The studs are a mild press fit and usually splined. Install a new stud with a press or use a lug nut with washers built up to pull the new stud into place.
I'm sure someone will chime in with info specific to the C6. Oh and in the future don't gorilla torque the lug nuts. |
Originally Posted by 06LEMANSC6
(Post 1560806756)
I'm sure someone will chime in with info specific to the C6. Oh and in the future don't gorilla torque the lug nuts. Lay off the steroids, Barry! |
Rotor against bolt...rotor wins
Take rotor off, put in vise with undersize socket, tighten vise, reverse with large deep socket over threaded end of bolt, clamp down.....done deal.....:D :cool: :D
I think you guys are missing something important. The studs are not part of the rotor.
The good news is that they are easy to replace. |
Originally Posted by jschindler
(Post 1560807476)
The good news is that they are easy to replace. I would also want to find out why the stud sheared off, most likely over tightened but could be something else too. |
Originally Posted by BRIANSC6
(Post 1560806705)
Thanks I am sure you know never oil the wheel stud threads. The 100 lb-ft lug nut torque spec is with "dry" threads. If one oiled the threads the resulting clamping load (and tension in the studs) increases exponentially with the torque. Also, ALWAYS use a qualified torque wrench. |
Originally Posted by calemasters
(Post 1560807582)
(Post 1560807476)
(Post 1560807589)
Some people also don't know that the longer the "extension" you use, the more you are multiplying the torque.
Now, if you use a longer wrench, you can apply a higher torque with less hand force, but a torque wrench will "click" at the same torque level, no matter how long the wrench handle. |
Originally Posted by mneblett
(Post 1560807774)
Huh? The length of the extension (from the socket to the wrench) has no effect at all on the torque applied to the lugnut.
Now, if you use a longer wrench, you can apply a higher torque with less hand force, but a torque wrench will "click" at the same torque level, no matter how long the wrench handle. :iagree: :iagree: :iagree: |
(Post 1560807774)
Thanks guys for info I am glad the stud can just be replaced and I will be asking why it snapped off.
(Post 1560808357)
Write it off to "defects in materials or workmanship", and be sure that everyone that changes your wheels in the future torques the lug nuts to 100 ft-lbs. I can't see it being over-torque...it was most likely just a faulty stud. Stuff happens.:thumbs: |
Originally Posted by talldude67
(Post 1560807419)
(Post 1560807774)
Now, if you use a longer wrench, you can apply a higher torque with less hand force, but a torque wrench will "click" at the same torque level, no matter how long the wrench handle. EDIT- I just did some googling, and it appears my teacher was wrong (or a lot of other people are). Damn, no wonder I went into sales instead of becoming a mechanic :yesnod: |
(Post 1560808620)
That's what I was taught in school many years ago. I have no way of measuring it, so I'm going by what my auto mechanics teacher taught us.
(Post 1560807476)
Originally Posted by JmpnJckFlsh
(Post 1560808858)
Ah, you were thinking about the hot new chick in school instead of paying attention...he was talking about the length of the wrench handle. :lol:
(Post 1560808620)
