TH400 on engine stand
Can a TH400 be safely mounted on a engine stand? I want to clean it up, changes filter and seals. It sure would easier than working on the floor.
Thanks |
For sure, just bolt it up like you would an engine.
Originally Posted by Jim71Vette
(Post 1560908078)
Thanks |
Take the pan off before mounting it on the stand, no need to have whatever junk has acumulated in the pan to get dripped back into the tranny.
Thanks... I was hoping I could do this, I was worried about the aluminum case. Now just have to find a good engine cradle so I can get the engine off the stand.
Breaking my own rule and posting this to help you.
http://img.photobucket.com/albums/v2.../TH4000001.jpg |
That looks like a complicated fixture. I'm thinking of using the "bell housing" flange to mount to engine stand. I just need to hold it so I can change the filter and seals, and clean it.
Thanks |
Vader Vette
Hey while ya got it out why not swap it to A 200r while at the summit nationals this weekend I had the chance to talk to the tranny guys there,they talked up the TV cable set up and the way the tranny used the engine to set the tranny . Ive checked $900.00 shipped all the cables sounded like A new tranny cooler everything need to change somethingout not sure what it is but 33 percent better gas milage the thing would pay for itself. Just A thought Im sure someone would buy the old one too.Bowties overdrives.I think is the name of the company.
Is the 200R a "bolt in" for the TH400 with no modifications to anything? Can I use original shifter and lingage? Sounds like a good way to go now that gas 3.50 a gallon.
Check out corvettefaq,, theres a couple good articles about swapping the 400 to a 200. A few thing that needs to be done but relativly simple if you do your homework. The yoke has to be changed and the TV cable is somewhat touchy adjusting. :D
(Post 1560909611)
I bolted up a th350 to the engine stand using the trans housing bolts. No problems. But be advised normally it would also be supported by the rear mount. I didn't have the torque converter on either.
(Post 1560909611)
