Roll bars for 07 Vert
Looking for roll bars for 07 vert...... who has them and where to buy. This will be a weekend track car and still want good looks for the street.
What does it take for install. Looking for input Thanks |
Check with Pfafted ( forum vender) he was working on one for verts.
There will need to be plates welded to the frame of the car so the roll bar can bolt on to it. ALso check with clubs you run with. They may have differnt rules as to what you can use . Most tracks and clubs require a minium of SCCA Solo I tech regs PLUS pass the broom stick rule. Roll bar is 2" min above the top of your head |
Best bet is to probably find a local rollcage shop and see if they'll build you something custom. (That is after doing what Tom suggested regarding double-checking the club/track rules.)
I been looking for some hoops for the C5 vert. Called Wolfe Racecraft, and they said no dice. I'm after hoops that are functional, not decorative, but I want them to look good. THinking custom is our best bet. I had not thought of Pfadt.
No Hoops. Tracks and car clubs will not allow hoops. Must be one continiurs bar over both passangers heads. Min clearence is 2" above your helmet
Originally Posted by AU N EGL
(Post 1561001595)
Thanks for the info |
(Post 1561001595)
(Post 1561001595)
Originally Posted by ICaughtVetteFever
(Post 1561007170)
SCCA book allows for hoops, do you know otherwise?
One continious Hoop from side to side, with diagonal tube and at least two down tubes. ALso look at the min diameter of the tubing per cars weight. SOme cars have factory installed Hoops. and these are strong enough for SCCA SOLO I use. The Corvette does not have this option Viper Boxter 911 Carrara Audi TT Honda S2000 Have factory install hoops that are strong enough to pass tech. Some clubs also require the Brey-Krause Hoop extender, bar that goes over the top of and accorss from one hoop to the other. Plus the broom stick rule. When a broom stick is placed on the top of the windscreen and the top of the roll hoop, over the helmet there must be at least 2" of clearence. Plus FIA padding with in 6" of where the driver and passanger could possibly contant the roll bar. Swing out door bars are not allowed. I dont mean to be a PIA but I hate to see guys think they can pass a tech inspection, go to an event and get kicked out. It has happened. I have seen guys with $2000 custom roll bars get kicked out of events because the tubing used was too thin for the weight of the car. |
Almost all Clubs refer to the SCCA Solo I technical rules for roll over protection:
----- Roll Bars & Cages Production Item 1: a. The main hoop shall be continuous and as near to the roof as possible on closed automobiles. Item 2. a. The main hoop shall be continuous and not less than two (2) inches above the driver's helmet on open automobiles, with the driver seated normally and restrained by seat belt/shoulder harness as illustrated in Figure 7A. Item 3: a.. The main hoop shall be full height (over the driver) for at least 50% of the width of the hoop a minimum of 9 inches as illustrated in Figure 7A below. For measurement purposes, a flat ruler must have at least 9 inches in contact with the tube when placed on the flat, full height section over the driver's head. Item 5. Bracing - Open and Closed Automobiles; and add a new paragraph to section 18.6.1.a as follows: All main hoops shall incorporate a a. Main Hoop Bracing: Rear Braces: All main hoops shall have two (2) braces extending to the rear, attaching to the frame or chassis. Braces shall be attached as near possible to the top of the main hoop not more than six (6) inches below the top), be outboard as much as possible, and at an included angle of at least thirty (30) degrees. Rear braces may penetrate required bodywork provided the resulting hole serves no other function, and the holes are sealed around the braces. Diagonal Braces: All main hoops shall incorporate a diagonal brace to prevent lateral distortion of the main hoop. The brace shall either be in the place of the main hoop, or extend from the top one rear brace (described above) to the bottom of the opposite rear brace. Automobiles with mid mounted engines can have the lower mounting point attach to the frame of the automobile within 6 inches of the main hoop. In the case of braces in the plane of the main hoop, the brace must span at least 50 percent of the width of the main hoop, and at least 75 percent of the height the main hoop. Refer to the figure.adjacent. Material: A. Seamless, or DOM (Drawn Over Mandrel) mild steel tubing (SAE 1010, 1020, 1025) or equivalent, or alloy steel tubing (SAE, 4130) shall be used for all roll cage structures. Proof of use of alloy steel is the responsibility of the entrant. B. Minimum tubing sizes (all Formula, Sports Racing, GT, and Production Category automobiles, and all automobiles registered prior to June 1, 1994) for all required roll cage elements (All dimensions in inches): Vehicle Weight Material Without Driver Mild Steel Alloy Steel Up to 1500 lbs. 1.375 x .095 1.375 x .080 1500-2500 lbs. 1.50 x .095 1.375 x .095 Over 2500 lbs. 1.50 x .120 1.50 x .095 1.625 x .120 1.75 x .095 C. Minimum tubing sizes for (all Showroom Stock, Touring and Improved Touring Category auto-mobiles registered after June 1, 1994) for all required roll cage elements (All dimensions in inches): Up to 1500 lbs. 1.375 x .095 DOM / Seamless / Alloy 1501-2200 lbs. 1.500 x .095 DOM / Seamless / Alloy 2201-3000 lbs. 1.500 x .120 DOM / Seamless / Alloy 1.625 x .120 DOM / Seamless / Alloy 1.750 x .095 DOM / Seamless / Alloy An inspection hole at least 3/16 inch diameter, but no greater than 1/4 inch diameter shall be drilled in a non-critical area of the front and rear hoop as well as the one of the supplemental braces to facilitate verification of wall thickness. Formula Cars and Sports Racers with alternate roll structures are not required to have inspection holes, the wall thickness will be indicated on the back of the homologation certificate. General Construction A. One (1) continuous length of tubing shall be used for the main hoop member with smooth continuous bends and no evidence of crimping or wall failure. The radius of bends in the roll cage hoop (measured at centerline of tubing) shall not be less than three (3) times the diameter of the tubing. Whenever possible, the roll cage hoop should start from the floor of the car, and, in the case of tube frame construction, be attached to the chassis tubes by means of gussets or sheet metal webs with support tubes beneath the joints to distribute the loads. It is recommended that gussets be used B. Welding shall conform to American Welding Society D1.1:2002, Structural Welding Code, Steel Chapter 10, Tubular Structures. Whenever D1.1 refers to “the Engineer” this shall be interpreted to be the owner of the vehicle. Welds shall be continuous around the entire tubular structure. All welds shall be visually inspected and shall be acceptable if the following conditions are satisfied: 1. The weld shall have no cracks. 2. Thorough fusion shall exist between weld metal and base metal. 3. All craters shall be filled to the cross section of the weld. 4. Undercut shall be no more than 0.01 inch deep. C. Aluminum bronze or silicon bronze welding technique is permitted, but extreme care shall be used in preparation of parts before bronze welding and in the design of the attaching joints. Touring Roll Hoops page GCR -106 TOURING ROLL CAGES 1. All cars registered after 1/1/03 shall conform to these roll cage rules. Effective 1/1/08 all Touring cars shall conform to these roll cage rules. Full width roll cages are required in all Touring automobiles. Roll cages installed in Touring automobiles are for driver safety and shall be contained entirely within the driver/ passenger compartment without removing any panel or accessory not specifically authorized in these rules. The carpet/padding may be cut around the mounting base plates. A. The cage shall be welded to the car, and all mandatory tubes shall use welded joint construction. B. It shall attach to the car at no more than eight (8) points, with the forward section of the cage attaching to the front bulkhead or front fender wells (see GCR Section 18.2., Figure 1). C. The front down tubes of the cage shall be mounted to the floor of the vehicle. 2. For tubing sizes for front hoop, main hoop, and all required bracing, see GCR Section 18.1.6.C. It is recommended that gussets (flat steel, tubing, etc.) be utilized to strengthen the joints of all required cage elements. Main Roll Hoop: A. Main roll hoop (behind the driver) shall extend the full width of the driver/passenger compartment and shall be as near the roof as possible. It shall incorporate a diagonal lateral brace to prevent lateral distortion of the hoop (See Figure 1). Any number of additional tubes/braces are permitted within the structure of the cage. It is required that the horizontal brace behind the driver’s seat (described in Section 18.2.10) continue from the diagonal to the passenger side main hoop upright or that a second diagonal be installed in the main hoop. 4. Front Roll Hoops: A. The front or side hoops shall follow the line of the front pillars to the top of the windshield (as close to the roof as possible) then horizontally to the rear attaching to the main hoop. These two side hoops are to be connected together by a tube over the top of the windshield, or B. A front hoop following the line of the front pillars and connected by horizontal bars to the main hoop on each side at the top may be used, or C. A top “halo” hoop following the roofline from the main hoop to the windshield with forward down tubes following the line 5. Bracing: The main roll hoop shall have two braces extending to the rear attaching to the frame or chassis. Braces shall be attached as near as possible to the top of the main hoop but, not more than six (6) inches below the top and at an included angle of at least thirty (30) degrees. On cars where the rear window/bulkhead prohibits the installation of rear braces (e.g., Honda del Sol), the main hoop shall be attached to the body by plates welded to the cage and bolted to the stock shoulder harness mounting points. This installation design must also incorporate a diagonal bar connecting the top of the main hoop to the lower front passenger side mounting point (“Petty Bar”). A. Rear hoop braces may pass through the factory bulkhead or panel separating the driver/passenger compartment from the trunk/cargo area/, fuel tank/fuel cell area, provided the bulkhead is sealed around said cage braces. Metal tape may be used to seal the openings between the bulkhead and the tubes. 6. Side Protection: Two side protection tubes (door bars) are mandatory on each side of the car. NASCAR-style side protection is required on the driver’s side and is optional on the passenger side. The driver’s window safety net may be mounted to this side protection and the top cage tube. NASCAR-style side protection tubes shall extend into the door. The door window glass, window operating mechanism, inner door trim panel, armrest, map pockets, and inside door latch/lock operating mechanism may be removed only if it interfered with the installation of NASCAR-style side protection tubes. The inner door structural panel may be modified, but not removed to facilitate this type of side protection. The stock side impact beam and the outside door latch/lock operating mechanism shall not be removed or modified. D. The mounting plate may be multi-angled but must not exceed these dimensions in a flat plane. E. Any number of tubes may attach to the plate or each other. 8. The driver’s seat shall be firmly mounted to the structure of the car. In cars where the seat is upright the back of the seat shall be firmly attached to the main roll hoop, or it’s cross bracing, so as to provide aft and lateral support. Seats homologated to and mounted in accordance with FIA standard 8855-1999 or higher need not have the seat back attached to the roll structure. The homologation labels must be visible. Seat supports shall be of the type listed on FIA technical list No.12 (lateral, bottom, etc). A. Each mounting plate shall be at least .080 thick. B. Each mounting plate shall not be greater than 100 square inches and shall be no greater than twelve (12) inches or less than two (2) inches on a side. C. Whenever possible, mounting plates shall extend onto a vertical section of the structure (such as a rocker box). |
This is good information!
Thanks! |
