Inexpensive Z06 bra?
Want one for the ride home(900 miles) from the Museum. Will only use it then, so don't want to spend big bucks.
Thanks in advance! |
Thought you were going to go with the Cleartastic?
http://forums.corvetteforum.com/show....php?t=1792116 If you don't want to hassle with the Cleartastic, you may want to check out this spray-on solution from Duplicolor. http://www.duplicolor.com/products/shield.html :thumbs: |
I also have been wanting some front end protection without dropping $750 bucks for a "color match" bra. I don't care if it's camo or baby sh*t brown...I just want a bra for the track.
What's so hard about snipping out a little material for the scoop from a C6 bra? could careless if it's a 1/2 inch short on each side...common some vendor step up to the plate and fill this void! How many color matched $750 bras have you sold anyway? |
Colgan Bra
I use a Colgan Bra for my Z....Easy on Easy off....Works great....no Flapping in the wind.... Nearly Identical to GM Factory item....I'm Very Happy with it.....$129.00....
Originally Posted by HIRISC
(Post 1561669543)
http://forums.corvetteforum.com/show....php?t=1792116 If you don't want to hassle with the Cleartastic, you may want to check out this spray-on solution from Duplicolor. http://www.duplicolor.com/products/shield.html :thumbs: LMK if you know otherwise. Thanks! |
Originally Posted by Z Sarge
(Post 1561669609)
I have a colgan and it was OK for the ride home, but at high speed the area right in front of the wheels flaps outward and sometimes the the top hook that attaches inside the wheelwell comes loose.
If I had done it again, I'd get this:http://www.zip-products.com/Corvette...5F29DDE2C55E71 |
Originally Posted by El Puto
(Post 1561677727)
