what injectors for an 86? 36# an upgrade?
Hi, what injectors are stock in an 86 vette? 28 lb?
I have a friend that will give me 8 new Siemens 36 lb injectors. What else would need to be done if I were to use them? Thanks |
36# injectors are way too big for your 86, and won't work without a new computer chip.
Pretty sure the 86 uses 18# injectors.
[RICHR] |
22 lbs, stock for 86.
Originally Posted by AGENT 86
(Post 1561935782)
22 lbs units can be pushed with a tune to work with most bolt-on mods. Once the mods go to wild side 24's are recommended to reduce duty cycle. :cheers: |
