In-Car Lap Timers...what's everyone running??
Looking for a in-car lap timer..what are my options?? Recommendations? Products to avoid???
Let me know..thanks. :cheers: :lurk: |
I had good success with a HotLap in the past. Lots of folks seem to like the new Ultra-Lap.
http://www.longacreracing.com/catalo...t.asp?catid=10 http://www.cc-2000.com/xtracing/en/ I'm leaning towards a DL1 eventually, though... GPS track maps, data acquisition and lap timing... $1000 vs $250, though. |
The TraqMate system was talked about a few weeks ago .
Priced around $1000 for complete system. http://www.traqmate.com/ http://www.youtube.com/watch?v=JbHP3KrbKps |
I have Traqmate, best bang for buck that I know of. But if you just want lap times, AMB should do, I have that too, for NASA. But for great data (and new updates every few months) Traqmate is awesome, I think it will be able to do everything the big units can do within 2 years (the ones that cost 3k etc). The updates are awesome.
I used an Ultra-lap but kept leaving the transmitter behind at the track. Picked up a PerformanceBox (GPS data acquisition) for $500 and I'm very glad I made the jump, much more useful than just a lap timer and even I would have a hard time losing it.
How do you mount it? I really don't trust windshield suction cups all that much. It looks like you get lap times, segment times, and Gs?
As for the AMB suggestion-- that only works if you run with a group that pays the track to turn on the timing loop, no? |
Originally Posted by gkmccready
(Post 1562026788)
Another beacon style lap timer is AIM. IIRC AIM is compatible with an Ultralap beacon. Hotlap and Ultralap are not compatible |
I use an Intercomp in car timer. It receives a beacon signal. It's seems to be compatible with about all other beacon makes. I never put out my beacon, I use everyone elses.
Which timers allow you to access your times on mylaptimes.com?
:confused: |
Originally Posted by Falcon
(Post 1562028517)
Originally Posted by Maineiac
(Post 1562029126)
Who sells Intercomp timers? I heard some good things about Ultralap timers today at the track....and some not so good things about Hotlap timers... :leaving:
The Intercomp also allows you to download your times into your computer. |
(Post 1562026788)
(Post 1562029118)
:confused: Hotlap timers get alot of bad press, but I've used one for about 3 years and have had good results. I've run a couple of events using a Hotlap AND a transponder for comparison, and found the Hotlap pretty accurate compared to the transponder. Occasionally you'll get a bad, or no, lap reading, but overall I have no complaints. If I were buying a timer today, I would probably by an Ultralap as it has newer technology |
Originally Posted by joemoia
(Post 1562030640)
:iagree: Bought mine used and it works great as long as you keep the batteries fresh. :cheers: DH |
