What clutch did they use in 08 C6?
I'm pretty sure that the 08 C6 Z51 has the same trans as the Z06, but did they also use the same clutch, how bout diff and TQ tube???
Thanks, JB |
trannies:
base - MN6 Z51 - MZ6 Z06 - M12 Trannies are different. Z51 tranny is geared lower than either the Z06 or the base model. I haven't read anywhere nor would figure that they would drop the MZ6. It's great for pulling out of corners. |
They have superseded all clutches to the Z06 rating. No need to carry multi. part numbers. They started this in 07. when they upgraded the rear ends in all C6's to Z06 standards. The increase in cost was mininal.
Originally Posted by andreas g.
(Post 1562312180)
Originally Posted by codename Bil Doe
(Post 1562303331)
trannies:
Someone posted the slide that all 08 models use the same transmission. Not sure about the clutch, but I would assume so.
http://forums.corvetteforum.com/show...ht=2008+tr6060 |
The only thing I know is that it has the same problems as the older C6's. My co-worker has 700 miles on his 2008 Z51 and while on his way home from work Sunday, the clutch went to the floor and didn't come up until he pulled it up with his foot so he could get home. Taking it to the shop today.
Originally Posted by Orbit
(Post 1562322748)
Originally Posted by Zig
(Post 1562322797)
me wonders if this an 'air in the line/system' issue. any idea if they bleed or burb the system at the factory after they fill it?
(Post 1562312180)
Ryan |
(Post 1562312180)
(Post 1562312180)
Originally Posted by reidry
(Post 1562323040)
I do not believe the standard C6 has the Z06 differential. There are no gears available (yet) to change ratios for the 9" Z06 differential, it is common to change gears in the 8.5" C6 Coupe/Vert differential.
Ryan |
(Post 1562322748)
Originally Posted by jbsblownc5
(Post 1562324471)
I've been under my 08 C6 Z51, and the Diff is large. I've also been in touch with Unitrax, and they don't quite have a diff ready for the 08s yet, so I'm quite sure the 08 Diff, at least on the Z51, and maybe on them all, is probably the same as the Z06.
I think you are referring to the tranny
(Post 1562312180)
Originally Posted by C6~Missle
(Post 1562323630)
Is this fact.. or hearsay...
(Post 1562324471)
I don't think the diff is the same on the z06 vs. regular c6 as the z06 has larger gears and a diff cooler.
Originally Posted by cfi_luz
(Post 1562330192)
