differences 2000 and 2002??
What, if any, are the major differences between the 2000 convertible and the 2002 convertible Vette? Thanx
2001 and newer have a higher power version of the LS1, 350/375 instead of 345/350. I can't remember any of the other differences but the engine upgrade was fairly substantial, the newer motors have much more low end grunt.
Originally Posted by mdchaser
(Post 1562451926)
Also starting 2001, A4'as do not have the column lock mechanism. |
Here was info posted on the forum a while back. There may be other differences too, but these are a good start.
Difference in Corvettes by year: 2000 • Millennium Yellow available • "Thin Spoke" versus "wagon wheel" design wheels become standard. • Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99) • Steel swaybar endlinks instead of plastic on Z51 equipped cars • Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06) • No keyhole on passenger side doorhandle • Passenger airbag 'off' switch added to console (light by TC/AH button) 2001 • Return to 28# injectors for all models. • Second Generation Active Handling • Nassau Blue discontinued • Alternator 'clutch' pulley added on A4 cars • New soundproofing + foam in all cars • Smaller keyfob • Electrochromic dimming rearview and driver's mirrors • Lighter AGM battery • Thickness + Material in Convertible change • Chrome exhaust tips for coupe + Convertible • 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT) • LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117) • All Corvettes now have the LS6 intake manifold • All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump. • LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6) • Hardtop/FRC discontinued • Stronger synchros in all transmissions • Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds • Metal valvestem caps (late year) • Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm. • Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability • Introduction of the Z06, which has as differences: • Hardtop body style • Rear brake ducting • Screened inlets on front fascia, without foglights • F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively • New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp • M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff • Titanium exhaust system • Lightweight windshield • New, stronger clutch with redesigned master + slave cylinder • Stronger rear differential (shotpeened ring gear) • Red brake calipers (otherwise identical) • Transmission overtemp warning light on DIC • 6500 redline gauges with special checkering + Z06 font • Redesigned PCV system to help combat oil burning • Red LS6 Fuel Rail Covers (FRC's) • FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51) 2002 • Z06 Changes: • Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5 • Less restrictive intake airbox lid • Descreened MAF • Removal of pup-cats (total with changes = 405hp) • Z06 shocks revised with less rebound for better launching • Z06 brake pads revised for better stopping (generate more dust) • Lighter, sodium filled valves w/ stronger valve springs • Higher tension rings installed to prevent oil burning problems • Slight piston redesign * • Clutch strength upgraded. • HUD available on Z06 (not avail '01 model year) • Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical • Electron Blue color offered • Steel endlinks changed to aluminum |
good post above..now we've all been schooled.
Thanks |
Originally Posted by CanadianVetster
(Post 1562457195)
Thanks |
