Times on stock motor....
Has anybody took their car to the track on stock motor (I mean stock car no mods)? What was your times? I took my last Friday and I got a 13.4
never mind I saw the sticky.
That's pretty good!
What type of car do you have? A4, M6, rear axle ratio? :thumbs: |
2000 Coupe Blue A4 all stock car...
do u know if you have the 273 or 315 rear axle?
Not bad, I ran my stock 98 other than the blackwing and it ran 13.7's and 13.8's in July and Aug in Florida heat/humidity.
Originally Posted by ALVETTE00
(Post 1562617867)
Originally Posted by Beach Dude
(Post 1562621532)
2000 A4 2:73
Best 0 - 60 4.81 sec Best 1/4 Mile @ Desoto 13.22 sec It's all in the launch, try not to spin but feather it out and get it to grip and rip! Then when it shifts to 2nd, Shift manually into 2nd during this time so you can ride 2nd gear to 6200 rpm (gets a better 0 - 100 mph time) or the car will shift @ 5600 :rolleyes: if you let it automatically. |
Not a bad time, my car in the heat bone stock ran a 13.4 then with the zip tie mod, Nittos and cool air it dropped to a 12.7
I keep seeing this zip tie mod... What is it?
Basicly you take the front of the air box off and zip tie the filter to the back of the air box. makes it an open element. Not as good as getting an air induction but a good cheap mod to do until you get one.
Originally Posted by deathstrike
(Post 1562624844)
I don't know... How can I find out?
I only had to car for about month so I didn't get the chance to run it during the summer. :thumbs: |
I ran a 13.30 @ 104.xx with a stock a4 convertible w/ 3:15s. The temp. outside at the time was 48 degrees.:thumbs:
13.4 good run thats a text book run for an auto stock. you should be happy :thumbs: I changed some stuff but not much see my sig. to get to 12.43.:thumbs:
Originally Posted by FRCBobby
(Post 1562625901)
Mybest time 13.449 @107 very humid and hot in August, stock '02 vert, A4, 2.73, Blackwing and Granatelli Cat Back.....I've since changed the old plugs/wires, and it feels much better now, but haven't been back to the track yet...
Nothing to brag about but I went back to the track and with the same ****ty tires I managed to pulled a 12 second pass with the vette
previous pass RT .615 60 2.412 330..5.976 1/8 .8.6 MPH..85.69 1000..11.300 1/4..13.27 MPH..109.61 __________________ today RT .326 60..2.154 330..5.60 1/8..8.43 MPH..86.98 1/4..12.92 MPH..110.40 Only thing done to the vette is B&B bullets 99 FRC |
Originally Posted by Slovette2000
(Post 1562795270)
I'd say it's safe to assume an average of 13.2 for MN6's and 13.3's for A4's with the ok gears and 13.4's for A4's with the crappy gears. These times are assuming a normal day at an average elevation with a decent driver that can launch.
my 98 a4 with a hypertech tune on street tires ran 13.30 @ 103mph in 05 degree with a 1.90 60' the rearend is 3:15
