TSP 233/239 Cam with Stock Heads, Dyno #'s & 1/4 Mile Time
See mods in sig, dynoed 380 rwhp 363 rwtq on a Mustang Dyno with crappy stock 853 casting heads and ran a best of 12.6 missing 4th gear at the track today, I will get a video up of it idling.
Yeah Don something isn't adding up. My guess is that car should be making into the 400rwhp range with that cam even on stock heads. You've deff got all the supporting mods. To go 12.6 at 109 dosen't make sense to me either because I run 12.60's at 114 on a stock cam. There has to be more power there. What's the lift and LSA of that cam?
Originally Posted by ParamedicC5
(Post 1562713067)
Yeah Don something isn't adding up. My guess is that car should be making into the 400rwhp rage with that cam even on stock heads. You've deff got all the supporting mods. To go 12.6 at 109 dosen't make sense to me either because I run 12.60's at 114 on a stop cam. There has to be more power there. What's the lift and LSA of that cam?
That is kinda odd. Ive ran 12.4 and 12.5's on stock heads and stock cam with stock F1 tires! Is the car pulling hard up top? Are you getting good traction?
My cam is similar and I put down 415rwhp and 390rwtq ran best of 11.24 so far on ET streets. All my mods are in sig.
Ran 11.6 on stock tires. |
Originally Posted by blk04z
(Post 1562880667)
Dynojet are alot more flattering when it comes to giving out numbers. Mustang Dynos can be as much as 10-15 more conservative..
Originally Posted by mitymikec
(Post 1562969365)
(Post 1562713067)
:iagree: that idle is wicked sounding!
that car sounds nuts
Do you have LT headers? Thats a lot of exhaust for the crappy stock GM manifolds.
Originally Posted by JDaniel
(Post 1562975862)
Originally Posted by JesseB
(Post 1562974943)
i agree, you should be getting more. Man that exhaust sounds good!
sounds awesome
I bet if you put on a set of heads it will really haul :cheers: savage1 |
Originally Posted by savage1
(Post 1563079334)
sounds awesome
My setup is very close to yours.Here's my chart before heads 401/379
http://i80.photobucket.com/albums/j1...s/DTEChart.jpg And after heads 442/395 http://i80.photobucket.com/albums/j1...Afterheads.jpg |
Originally Posted by Thanatos
(Post 1563124671)
Just bumping this thread, I should have a long time ago, new numbers after clutch w/ updated 1/4 mile time below in sig
