z51 oil change
I remember a post about something needs to be lubed at every z51 oil change.Anyone know what it is?
yes, lube the rear outer toe links at every oil change or track days.:thumbs:
Thanks. :cheers: happy Thanksgiving
Originally Posted by cranky
(Post 1562847392)
Originally Posted by agrumpyguy
(Post 1562846662)
A better interval is every other oil change or 10K miles whichever comes first. The best method is to simply feel the fitting seal, or visually inspect it to see if it's plump with grease...if you can feel or see that the seal has grease within, then greasing is not required. Overgreasing will lead to grease leakage from the seal and a mess on your rear wheels. |
Z51 Oil Change I don't get it?
Originally Posted by Jet Stream
(Post 1562848439)
BTW, I understand that some if not all FE3 cars also have these greasable end links. But I agree, not needed that often - 10,000 miles is probably overkill. And don't use a lot of grease - just a pump or two. |
(Post 1562848439)
Originally Posted by blkc6z51
(Post 1562848823)
What don't you get.
Originally Posted by JmpnJckFlsh
(Post 1562848366)
Unless you do a lot of tracking, you will likely find that lubing the rear toe links at EVERY oil change is unneccessary and will create a mess for you.
(Post 1562848866)
Look in the manual. Nothing special specified about Z51 and oil changes/lubes. Why don't people read the service instructions.
(Post 1562848866)
Originally Posted by cadguymark
(Post 1562850195)
the manual doesn't say anything about putting a Z51 emblem on it either, but that doesn't stop people from doing it:leaving:
For your information the z51 package does have different parts,than non z51 and the rear toe links need to be maintained. What does that have to do with emblems? Enjoy your Thanksgiving |
(Post 1562851498)
If you don't have an intelligent answer to the question posed,move on.Why do idiots have to get into the z51 envy mode anytime one is mentioned?
(Post 1562851542)
Z51 Envy??? :lol: :lol: :lol: Come on folks get real. Anyone that can a afford a new Corvette can afford a Z51 suspension option. Its the Chiropractor bill from the sore spine from the jarring suspension the Z51 offers is what they can't afford....:rofl:
(Post 1562848866)
Engine Oil with Filter 6.0L Engine 5.5 qt 6.0L Engine Performance Package (Z51) 6.0 qt 7.0L Engine 8.0 qt And, under "Maintenance Footnotes", footnote (b), in Section 6, Maintenance Schedule (page 6-7 in 2006): Visually inspect front and rear suspension and steering system for damaged, loose, or missing parts or signs of wear. Inspect power steering lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. If you have the Z51 performance package, lubricate the outer ends of both rear toe-links. Check your owner's manual and get back to us. Ya got to watch those footnotes...they'll nail ya. ;) |
(Post 1562851681)
It is exactly people like you I was referring to.All I did was use the resources of this forum to get an answer to a question I had about services specific to my z51 option.Many members gave me good info.Yet you chose to tell me why didn't I read the manual .I appreciate your very helpful advise.Then you get into thet old topic about the z51 is nothing special blah blah.Ifyou feel that strongly start your own thread and get off mine.:beatdeadhorse:
I'll say it again read the manual its the best source of information regarding service to your car. Not CorvetteForum.com :yesnod: |
my 2006 owner's manual says:
Scheduled Maintenance Service Maintenance II . . . . Inspect suspension and steering components. See footnote (b). • . . . . (b) Visually inspect front and rear suspension and steering system for damaged, loose, or missing parts or signs of wear. Inspect power steering lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. If you have the Z51 performance package, lubricate the outer ends of both rear toe-links. |
(Post 1562851709)
Maybe they've edited Z51 out of the 2008 manuals, but the 2006 Owner's Manual clearly indicates special attention for Z51 in the "Capacities and Specifications" section (page 5-101 in 2006):
Engine Oil with Filter 6.0L Engine 5.5 qt 6.0L Engine Performance Package (Z51) 6.0 qt 7.0L Engine 8.0 qt And, under "Maintenance Footnotes", footnote (b), in Section 6, Maintenance Schedule (page 6-7 in 2006): Visually inspect front and rear suspension and steering system for damaged, loose, or missing parts or signs of wear. Inspect power steering lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. If you have the Z51 performance package, lubricate the outer ends of both rear toe-links. Check your owner's manual and get back to us. Ya got to watch those footnotes...they'll nail ya. ;) Damn, it says the same thing in my 07 manual. Since I've read the manual and have seen the information on here, I would say that there if fact IS something different about the Z51 oil change and lube requirements as compared to the F55. Since I have the Z51 option, it is important to note that there is additional oil required AND the 2 lubrication points that need maintenance. |
Originally Posted by eboggs_jkvl
(Post 1562851983)
